OEM Display Issue - No Clock?
All things Altima Coupe.
IBCoupe
Car: '08 Nissan Altima Coupe 3.5SE
'19 Infiniti QX50 FWD
'17 BMW 330e iPerformance
Center of Dash:
And here's a close-up of the gap I can feel underneath. Note the position of the AUX cable insert in each photo; that should give you an idea as to where the gap is located.
DJ_B_Easy
Car: 2017 GMC Sierra All Terrain X
Alright...I cant tell 100% for sure, but the piece where that gap is should be 1 complete panel under the radio and above the changer, rectangle in shape. It just pops out, use a small scredriver and pry it out. Next you have to remove the actual HVAC vents above the radio, this one is a little more tricky. I run a small flathead down the right side until I can just get my finger behind it to hold it away from the dash, then re-angle the screwdriver more in towards the back and go top to bottom with it again. It might take a few tries but this too will just pop right out. Disconnect the air bag and hazard lights, put the whole thing aside. Now, you will see 2 screws at bottom where you removed the rectangle piece, 2 screws at top where you removed the HVAC vents. Remove them, gently pull the radio away from the dash.
