I think HC was 90/130 or some such and CO was like 2.5% on both 5mph and 25mph. NOx was like 600/1100. I've got a 240sx with a KA24DE with a header, 3" cat, 3" catback and an intake. Do you think it means anything that the #4 injector isn't clicking as loudly as the others? It's a very noticable difference in volume; you can barely hear it.NISTECH wrote:typically when all 3 readings fail it indicates a cat failure. What the numbers were actually helps asses the failure better for me. But having both CO and HC high does indicate rich condition but generally in that case NOx would be low due to the excess fuel cooling the cyl a bit. If you have your numbers to post as well as you specs it could be much more helpful.
Well, I know my EGR valve was screwy, I've since replaced it. Also, the #4 injector definitely isn't completely dead. Unplugging the harness makes the engine WAY rougher. The wierdest part is that I've replaced just about everything on the car. I haven't gotten a smog test since I replaced the most recent things (PCV valve, EGR valve, and that new MAF I tried) but I should be doing so soon.NISTECH wrote:Are you in california? I know othe states read it differently. But here we get maximum, average, and measured.
You may be hearing the other injectors click through the rail and #4 isnt doin anything. If it doesnt fire at all you would have a lean condition on that cyl. but the others would come up slightly to try to obtain proper fuel mixture. You may have a dead injector causeing SOME of your problem. But if all three readings are in the failing range I think there is more to it then just that.
Just replaced the O2 sensor actually. Tested it with a multimeter. Seemed to fluctuate between .735v and .45v or so fairly rapidly. Couldn't it just be a slight problem with the injector though? I guess it could be my knock sensor though. With my old one that was definitely bad I had similar symptoms...NISTECH wrote:How is your O2 sensor? If unplugging your # 4 injector is having a serious effect on your engine I seriously doubt thats your problem.
Well, I know the fuel pressure is good, as I had to get an adjustable fuel pressure regulator after I installed my walbro 255lph pump, so I doubt there's anything wrong with either of those. I also had the fuel rail off the other day, and it seemed like the #3 injector had a slight leak, so I replaced it with a new injector I had lying around. The #4 injector didn't seem to be outright leaking, but I'm thinking that it might not be operating correctly, or at the worst, the ECU might be sending bad signals :\. I'm going to try putting my MAF back on, as opposed to the new one. The new to me one I put on looks like it's in worse shape than mine anyhow.NISTECH wrote:I reread through your problem and a few things stood out [your injector code you had, your very high CO reading during the smog test,and your concern about #4 injector] Here is where I think you should go next.Get a fuel gauge on your car and do a injector leak down test. See if you have a leaking injector causing this engine to run rough.This is done by setting up your fuel gauge between the fuel filter and the fuel rail. You tee it in. Turn the key to the on position[dont start it] let your fuel pressure build, should pop up to around 40psi. After 5 sec's the pump shuts off. watch your pressure. It should not drop more then a few lbs when the pump shuts off. If it drops more then 10 to 15 lbs in only a matter of ~20sec's you have to determine where the pressure loss is coming from. You do this by repeating the test and pinching hoses one at a time till you have isolated different areas where the problem could be. start with the line between your fuel gauge and the fuel filter. If your leak down is no longer present you have a bad check valve on the pump. If the leak continues then you repeat the test and pinch the return line. If the leak down is no longer present then you have a bad pressure regulator. If the leak continues then you have a leaking injector(s).
well, I've had it off and nothing looks obviously corroded. I live in CA, so it's luckily not a big problem where I live, but there could definitely be a funky wire or something. It has to be something at the ECU at this point simply because like I said all the damn sensors are new.NISTECH wrote:Start playing with that harness down there. You might be onto something with it effecting the cars idle. You could have a bad/corroded connection down there.
