redrocket wrote:I have the NX Express wet kit and I was having problems with it. It felt like I was getting too much fuel and causing the engine to stutter so I got pissed and ripped the fuel solenoid out and now I am running a 70 jet and running it dry before the throttle body and the car is not leaning out at all I am really confused with the way the car is running because I am not running anything like you quoted me to and it seems to be working fine
How do you know that the car is not leaning out?AFR gauges realate only electrical impulses from the O2 Sensor on your header (If you even have an O2 Sensor after mods)Have you pulled out your spark plugs to look at them?Were they white? Grey? Black? Oily? Powdery? Did they still have electrodes?
a 70 jet on the NX system is a 020 pill size. (NX may rate this differently, but this is how the match up on a size chart.)and on a dry shot only produces about 45 hp.
The way you are running this system, and any knowledgable shop will tell you the same thing, is dangerous and foolish.
Try calling NX and explaining the problem to them, or the shop where you purchased the system.I am not 100% familiar with the NX setup, as I didn't like it, and it was too much trouble to tune on my cars so I went to N. O. S.
Try moving the jet for the system to before your MAF, and see the difference. Just cover your old hole with duct tape for a few minutes while you try it.
You will see a huge difference.
(Please note that cars with the temperature resistor Radio Shack mod will react VERY differently to Nitrous applications. The Temperature of the nitrous is typically about 36°F when it is released from the nozzle, and the sensor makes fuel adjustments to compensate.)
