nos
armory240
Car: cars sk8 boarding
what the hells nitrous? lol
MarkEmark
Car: fully-built '95 240sx KA-T
nitrous? they musta spellt nawwwwssss wrong...hahah, fools!
Flipity
NX all the way. better kit and it should only cost you like 500 or so. they also tend ot do more reasearch and devlopment while NOS does all the advertising.Just so you know most kits tend to operate when they are armed and at full throttle, but that can be changed so take that in mind. also remeber that the nitrous line itself has to hold like 1000 psi so it may be a good idea to run that securley under the car.
TrueSlide
Car: Stuff
So what would a good sensor be to check on fuel/air mixture?
Is a Knock sensor the same as a A/F sensor? If not, would the Knock sensor be more accurate?
Aries
Car: LT1 240SS
aftermarket engine management is the way to go.And no, a knock sensor is not the same as an AFR gauge.They're completely different, and used to get different readings.
