IvoryJ30t »
https://forums.nicoclub.com/ivoryj30t-u9485.html
Thu Nov 18, 2004 2:06 pm
no problem. i like helping people out who take the time to do things themselves.
ok, now. its weird that the ecu is giving 5v on the 7 pin terminal without the engine cranking/running.
the ecu uses positive pulses to the ignitor to fire the coil. if you are getting 5v on all of the pins on the 7 terminal plug [except for the ground pin 4] then the ecu may be shot.
going from the terminals on the 7 pin plug- using a multimeter, you should see pulses when reading from terminals 1, 2, 3, 5, 6, 7, to 4.
another words, connect the ground lead to pin 4, and use the positive lead to test the other pins.
if there is constant voltage on all of the pins, then the ecu may be bad.
also, check the coil wiring.
check for continuity between the signal pin on the coil harness, and the corresponding pin on the 7 pin terminal. do that for all the coils.
also make sure that there is no significant resistance between the ground pin on the coil harnesses and chassis/battery ground. do that for all coil harness connections.
report back your findings.
