oes »
https://forums.nicoclub.com/oes-u32276.html
Sat Feb 17, 2007 6:36 pm
1992 nissan 240sx ka24de-t w/ AEM EMS
Well I just got the car running finally. We were able to fire it up for the first time. Had it running for around 15minutes @ 2000rpms to do the cam seating. Right around 15minutes of running, the car dies on its own, we try to recrank it, and it wouldnt. Check for spark, no spark? Swap out coils with my other one and try to fire it up, no dice. We let it sit for a few mins and try once more and it fires up. After messing with some stuff we try again and it wont crank. We call it a day.
Few days later I go out and try to fire it up with no success. Decide to slap the battery charger on it and try. Fires up first time with charger running. Turn it off because I noticed a fuel leak. After fixing the leak, try to start it up again, it wont fire. Not getting spark again. Let it sit for awhile, fire it right up and let it run for about 10 minutes, then it starts to lose RPMs and then just dies. No more spark again!
Figured it might be a problem with the alternator so I take it out and take it to Autozone to get tested. Fails all tests (I dont trust their machine) but I buy a new one anyway. Replaced the alt and noticed the power/charge wire on the alt was ghetto rigged so I redo the wire and add a new connector. Try to start it up with new alt and no go again. Put the charger on it for about 45mins @ 12volt/2amp and try again, still no fire or spark.
I used a meter to test the voltage on the battery directly, was reading about 12.45volts. Noticed the EMS was reading 11.65 battery voltage with key on and when I was trying to crank it would drop down to 8-9volts. I have no idea what is going on. Any help?
