saif1587 wrote:Guyz,
I have just completed Installing the Pioneer 3300bt. Everything was working fine and i could play it. I've also installed a back camera which was also working fine. Suddenly no power! I checked the fuses(no 35 in main fuse box and no 20 beside steering). They are OK. Cant figure out what went wrong. Every other electrical is working fine. btw I checked the fuse of pioneer which is also fine and i swaped it with original OEM audio and that is also not getting any power.
Any words of wisdom?
model:Nissan Rogue 2008
CHECK THE CONNECTIONS. take the main plug out of the unit, and stick a grounded tester into the positive terminals to see if its getting power - odds are its not getting power from either of the connections. i hope you used a no splice wiring harness.
if you did splice - i hope you at least soldered the connections or pig tied them tightly, and then wrapped them with electrical tape. i hope you didnt use pig tail twists, nor simple crimps.
