Code: Select all
I just picked up a 2001 Pathfinder 2WD (3.5L) and am having huge issues already and I’m hoping somebody can point me in the right direction before I start throwing money/time at this rig.. I’ll split my story into parts..
PART 1
I previously owned a 93 Pathfinder (my favorite car ever) and I’m familiar with wrenching on cars. However, I’m at a loss for words with this recent one. Let me begin by saying, this Pathfinder sat for a couple years and comes with some baggage. The OEM key that came with the vehicle is missing it’s transponder so I can it turn over the car as of now. BUT, I did just buy the Nissan Data scan 2 and new transponder Keys in order to avoid the costly fees of a locksmith/dealer..
PART 2
And now here is my problem... After buying a new battery, I hooked up my scanner and found no codes (as expected). So, I started doing my research and found that the IACV in these vehicles tend to short out the ECM so I check both. The IACV was leaking so I knew it needed replacing so I ordered a new one and at the same time I cleaned out the throttle body. Next stop, check the ECM. I pulled it and found no signs of shorts/burnt parts. Good. Next, I replaced the spark plugs all gapped to .044, cleaned the MAF, and got the car ready for my new IACV..
PART 3 (Good Part)
Thursday morning comes and I receive a knock at my door. It’s my VAG-KKL connector and new transponder keys that I ordered with this Nissan Data Scan 2! I run outside, plug my battery back into the rig and attempt to attach my VAG-KKL/computer to the OBD2 port of the car... The power light comes on the VAG-KKL, my computer is acknowledging the adapter, and everything seems to be working fine when all of a sudden... NO COMMS.... In disbelief, I try and reconnect.... NO COMMS.. This can’t be. Did I get a faulty cable? I reach out to obdinnovations (website where I bought the NSD2) and mess with it for no kidding 6-7 hours. No dice. And then finally a light comes on in my head. Try the scanner and pull codes! Of course. So, I plug up the scanner, power light comes on and... NO COMMS (no communication)... No. the code scanner that previously worked was no longer connecting. What did I do? So, I pull out my multimeter and check all the pins on the OBD2/DLC.. Pin 16 reads 12v-12.4v, pin 4 & 5 resistance is 0.4-0.7... and pin 7 (k-line) 0v.... Now as far as I understand, the k-line is the data link to the ECM and there should be about 3.5v there and would signify data transfer.. So I check all of the fuses in the car and check my ECM again and found no burnt/shorted components.
CONCLUSION
I’m really at a loss for words here. I love Pathfinders so much and working on them makes it even better but I can’t tackle this problem alone. So I humbly ask the forums to help me in diagnosing and fixing the new to me pathfinder.... New ECU? Short in wiring? Please give me your thoughts. Thanks!!!
