you are correct about the Z32 ecu. But you will not be able to run the rb25 . I already checked and been talking with the guys at the other forums. do your H.W gtr forums and gtr skyline australia! there's more info there! but last time i checked it will ONLY be available during the SUMMER!! for the rb25 that is!Kansei240sx wrote:Dont use an RB20 ecu for a 25.
Use a VG30DE/TT Ecu from a 300zx, install nistune chip to ecu, re-pin a few wires on the main blue plug to the ECU. Done.
Nistune > Overpriced EMS's that dont even have factory maps to fall back on.
Learn something new everyday here! thx.. so a stock z32 ecu hunh? plug and play? is that better than the stock rb25ecu??Kansei240sx wrote:If you lurked around here more, you'd know that there are people already running RB25's with UNCHIPPED stock z32 ecu's. I've already got nistune on a VG30DETT ecu on my RB25 that works. I just dont have it running due to turbo upgrade etc....
No you will have to repin the connector... but i am not sure how involved that is... That and like they said you will need one that has VVTmean240 wrote:
thanks
Awesome thanks for the help! I am wiring stupid! Ill get the ecu and go back on thier website to see what i can find on the repin.l0nestar wrote:If memory serves, repin is 4 or 5 wires. I posted the pin changes here before - they are on the NisTune site. I believe under an FAQ.
Any Z32 ecu should work - you are updating the code on the ecu. Doesn't matter what the original rom says, your changing it, remember . pin-outs are the same.
Carl,Carl H wrote:make sure you get an 'early' z32 ecu as its 8-bit and is easily chippable...the 16bit version can be nistuned now but wasnt a few months ago.as far as installation goes i can install any nistune board and have proper tools to do so...there is a reason that i have a 250$ desoldering iron.
Reading the info on that harness it just says its an extension not a conversion harness... I was thinking it was a plug play from rb25 to z32meet07 wrote:
Its made by field one. $144.00 us dollars is what there asking. Here is the link.
http://www.rhdjapan.com/jdm-lo...55225
How is the 'factory' map going to work when you have redefined the load points (N01-N20) and recalibrated the airflow curve of the MAF????Kansei240sx wrote:Dont use an RB20 ecu for a 25.
