NISSAN HARDbody engine help
Mpollard
Car: 1994 nIssan d21
I bought a 94 hardbody with the single cam 2.4 in it it has a knock to it so I pulled the motor and it has a bad rod bearing. Is this motor a ka24e?
Yes, SOHC KA is the KA24e.
Typically bulletproof, but a good opportunity to do a DOHC swap!
Mpollard
I believe the timing chain ate the guides and trashed the pickup and starved for oil
Ah. Yep, lack of maintenance.
Keep us posted on what you decide to do!
Mpollard
WHAT ALL has to be done to do the dohc swap? Are those motors easier to find
If you go with the frontier KA24de its a direct swap.
https://forums.nicoclub.com/ka24de-swap ... 25886.html
Find a wrecked Frontier, or search "KA24DE frontier engine for sale."
Mike098765432@1
Car: 1997 Nissan pickup 2400 12 valve 2.4 L 4-cylinder
Okay I'm trying to figure out some questions here I have a 97 Nissan hardbody pickup with the ka24e motor trying to figure out if a 93 ka24e will work I know the Distributors aren't the same so how would I make this motor work for this truck
Desert Rat
Car: 2014 370Z M6 Base Coupe
2017 Frontier 4.0
2007 Dodge Ram 2500 Cummins Quad Cab 4x4
1977 F150 4x4 Shorty BUILT
2008 Boulevard C90T
Previous owner of a bunch of Nissans
You need a truck motor. A DE motor from 1993 is going to likely be from a 240SX, which I believe has a different bell pattern and won't bolt up to a truck trans.
You need a 98-04 truck motor.
Mike098765432@1
That's the thing I already got the motor in bolt it up to the transmission everything lineup good but when I went to hook up the wires for the distributor the 97 has a built-in coil and 93 does it and I'm wondering if I just probably have to splicing into the harness and put a coil in that's the only thing I can think of or that or like you said get a new motor got any ideas
jonathan1173
Car: 1997 Nissan Pickup XE 4X2
Since you have the 97s wiring harness, I'd check if the distributor from a 97 would fit in the 93 motors distributor opening. If not, see if the front timing cover from a 97 will bolt onto the 93 motors block.
The distributor bolts into the front cover and its gears mesh with those of the crank sprocket and oil pump.
Check the part # and pics for the front cover from both a 93 and a 97 that way you can ensure they're compatible before buying/installing.
