a.blanco0905 »
https://forums.nicoclub.com/a-blanco0905-u174687.html
Tue May 17, 2011 3:55 pm
^Yesssss... I felt the same effing way man, I'm normally not so patient when I'm working on my cars/motorcycles but to be honest I really needed to not spend any more money than what I had already paid for them... neither installing them nor buying that piece that you cracked, so for the first time ever I took my sweet as$ time and manage to not break it. Had these lights not been so expensive I would've broken that trunk cover piece... wtf was Nissan thinking when they built our trunk anyways? I spent about 45 minutes just trying to figure out how not to break them... and this is how you do it, after you unscrew the obvious bolts, you pull up on that piece and expose 3M double sided tape, you will see it flexing and you just cut it with a blade all the way down, and then you do all the hidden bolts & plastic tabs and whatnot. But that double sided tape is what makes it so much harder.
