the z32 bushings "kinda" fit from what i've heard. my pineapple bushings for the 240 went in with no problemsddgsxr504 wrote:Use Z32 kit from Energy Suspension, they offer the actual poly bushing.
They fit, the only problem I've seen when using them is that they are slightly taller and give you less threads on the stud when re-installing them on the chassis. That is easily remedied by putting a steel washer and nuts without the built in washer in them.White Comet wrote:the z32 bushings "kinda" fit from what i've heard. my pineapple bushings for the 240 went in with no problems
sh*t's expensive on enjuku for no apparent reason, i have found better stuff elsewhere for less. but they're still a cool company.mmm240 wrote:I can't believe anyone would pay that much just for the rear subframe bushings. Most anyone would need is the inserts that come in the master set that is 40-50 bucks less.
i know right, its so stupid of me to spend $65 on a full bushing, instead of relying on a flimsy insert and 20 year old bushingsmmm240 wrote:I can't believe anyone would pay that much just for the rear subframe bushings. Most anyone would need is the inserts that come in the master set that is 40-50 bucks less.
Yeah. Who would want to modify their car? Silly parts replacers.mmm240 wrote:But hey, if you prefer to waste your money on things that don't need replacing; fine by me.
so is there a reason you are replacing ALL of your suspension arms?Burnout240 wrote:I have a quick couple questions guys. The ES Master Kit seems like a little overkill. I mean say you're going to be replacing most of your suspension with aftermarket parts. The new bushings on them will be better than the stock ones. So would there be any point in replacing the bushings on the new parts with the ES ones? I'm just asking because I'll be replacing all the stock suspension parts and I think it would make sense for ME to just go ahead and buy the bings.ca subframe bushing inserts. What do you guys think? Thanks
Unless of course you want to alter your ride height significantly. Or you just want a better "feel". I plan on replacing all of mine with spc arms, and I think I will probably feel the money was well spent.hbpignosePA wrote:
that is overkill on a street car.
if your building a track terror with a high hp motor then by all means replace all of the arms. nissan engineering is good enough for auto x, and spritied driving.
You gotta draw the line somewhere. $180? No, $65? Maybe. It's that most here DD their cars and being that stiff is annoying and pointless; track days excluded of course.Crazyirish wrote:
QFT. I'm running KYBs and S techs and it's great for a street car. I don't that some ricer thinks my car isn't low enough.hbpignosePA wrote:
id rather just buy higher end car with that kindof money.. i cant justify spending that much on just suspension on a car that is worth 3k max
not to mention, alot of high end suspension parts are made for the track not the street.... so if the roads are terrible like they are here it will significantly lower the life of the products.. not worth it imho
ill probably get RUCAs and thats it in the back
hbpignosePA wrote:what sort of events do you do?
if your not into drifiting theres always the helical diff from the s15. im currently installing one in my car, check out my build it should be in this weekend.
oem ftw
