WelcomeMasterKen wrote:Cool beans man, thanks for the info
WelcomeRBKIDD wrote:yea ur rite he did answer my question the first time lol thanx for the info
jonnie fraz is the guy who owns Stealth Fab and he is on Z i l v i a . n e tmutiny wrote:where they sell the stealth fab brace stuff anyways
I had this problem too! I stuck a screwdriver in the hole on one side and manned up on it while I inserted the bolt from the other side. Keep at it, eventually you will push the bolt right through! Once you get it about halfway through, it's hammer time and man up with the leverage on that screwdriver!Cruiserdude wrote:We're installing Tein T/C rods at the same time, and I'm talking about the hole where the tapered bolt goes through to hold the end of the t/c rods in place, so its all new parts, no chassis involved. It's not that the bolt holes don't line up, but that the reinforcement for the hole isn't quite lined up with the hole, like the problem is completely in the power brace. Wish I had pics, I'll try to get some if we can't fix it, but I'm just wondering whether to use a file, or a drill, or what?
Mike, if you see this, maybe you can help explain it a bit better....?
Well, you can do that, but... Loose other bolts on power brace first, so you can have some slack. You put those long bolts first and tighten other bolts on power brace. You know what I mean? Rubber bushing will get twist as you tighten the bolts on power brace and nuts on tension rods. It's just matter of which bolts and nuts you tighten first.positronone wrote:I had this problem too! I stuck a screwdriver in the hole on one side and manned up on it while I inserted the bolt from the other side. Keep at it, eventually you will push the bolt right through!
Makes perfect sense! Wish I had thought of that. Shows how impatience can get in the way of a install! +1 to 94_240sx!!!!94_240sx wrote:
Guys, that's not how you do it. Loose other bolts on power brace first, so you can have some slack. You put those long bolts first and tighten other bolts on power brace. You know what I mean? Rubber bushing will get twist as you tighten the bolts on power brace and nuts on tension rods. It's just matter of which bolts and nuts you tighten first.
That's exactly the problem I was talking about, thanks for the advice, I'll have to try that next time we get a day to work on the car. I'll be sure to let y'all know once we figure it out, thanks for all the help!positronone wrote:I had this problem too!
Ok as requested here is his contact info, he is a user here on Nico but he just doesnt post much. As for the welded version that I have, Jon and I are the only two that have it, the reason being is I live like 5 mins from him and brought my brackets over to him. The bolt on versions were made so people didnt have to send him their brackets, funny thing is Jon has used both on his car and they are actually just as stiff as the welded version. This is most likely due to the fact that the outer plates that sandwich the entire bracket. You could always buy the bolt on version and weld it up yourself too.94_240sx wrote:Stealth fab welded version looks awsome. I like it a lot. Those square boxes are bigger than Nismo version, so it should be slightly stronger than Nismo one I guess.
Yea its a rubber bushing that lines up the metal sleev in the TC rod, that is why it was off. Like everyone else said on here just pick a way and you should hav eno issues getting the bolt thru. When I did mine I just pushed the LCA forward till the bolt went in.theclub wrote:I put the large bolt in first then the two smaller bolts that conect the tc to the lower main arm, everything fit perfect for me (no hamering requiered).
