Yup.sleepyRPS13 wrote:did you put the right mount to the leftside and the left mount to the right?
Thanks for the help. Unfortunately, they will not clear the KA - or at least my sohc.S14SRPilot wrote:The CUSCO flat oval bar will clear NISMO mounts. This is on my s14 with an s14 sr:
It's been about 2 months, hehe. That things rock solid and ain't sinking any time soon.EstoMax wrote:maybe if it settles itll lower enough to get the bar on.. drive it for like a week and see
B4:ClubSX wrote:Hey, i got a question..
How good are the Nismo motor mounts. They caught my attention a few months ago and was pending if i should get them when i swap
I "believe" the ones w/ the problems closing the hood are the sohc engines, which seem to sit a little higher than dohc stock for stock. So yea, iono...Dark-Hawk wrote:Yeah my Megan strut bar wouldn't clear either. I love the NISMO mounts though. I didn't reverse the mounts but my hood closes fines..?
You have an sr tho right loveless? the sr doesn't have this problem.Loveless wrote:I have the cusco 40D, it will clear also
hmmmm, then maybe it doesn't make a difference...Dark-Hawk wrote:brokeAs240sx: I have an SOHC
I thought about doing that... look at how much space there is on the strut bolts - not that much. And I don't know if I want to put that much force on the studs even if I get extended ones (i.e. it's no longer pushing against the tower & bolts, but now just the bolts.thekage wrote:try a few washers on top of the strut tower bolts and then putting the stb on?
Any way you can explain that a little clearer? I have no idea what you are talking about, haha.40daws wrote:I also have a KA24E with nismo mounts-not currently running a strut bar though. When we lowered the engine back into the car (rebuilt the engine ) I started tightening everthing and the guy that was helping me had me take the mount bolts back off because the mounts weren'tsitting right. I said what ? and he showed me the little "nib" on the bottom of the mount was not down inside the "semi circle" the stud goes through also. So with some pry bar action we got the "nib" and the stud both sitting in the "semi-circle". I'm just wondering if this little bit is whats keeping those of you with strut bars from bolting them up.
