Nismo Motor Mounts installed - now won't clear strut bar :(
40daws
http://www.zilvia.net/f/showth...MOUNTgo to this link from zilvia and scroll down to the picture of the new nismo mount and old stock mount. you can see the main "stud" and next to it the "nib"on the new mount. Its almost completely worn off the old mount in the pic. mine where the same. hope this helped explain my earlier post.
Modified by 40daws at 9:39 AM 12/16/2005
Modified by 40daws at 9:41 AM 12/16/2005
Chezedik
Car: 1991 Nissan 240sx
Bad Link ^
40daws
edited link,try it now .
onosqv
Car: '92 240sx Vert
Chezedik wrote:Really, there is a relation between the motor's height and the vibration? Does anyone know why?
I don't believe it's height. I believe it's material construction, etc.
If you look @ kazama, cusco, jgs, etc - they are just seemingly 1 single chunk of polyurethane. If you look @ nismo mount, it has more ridges, dampening etc.
And o, that nib, yea, I made sure that nib was sitting in the correct spot, thanks.
40daws
ok,well the mystery continues !
Chezedik
Good link^, also that answers my question, I will be going with the JGS mounts.
40daws
did anyone find a strut bar that would clear the SOHC with Nismo Mounts ?
thejapino
Car: '93 J30t
off topic but why would you reverse the engine mounts. aren't they the same for both sides?
HardStyleDrift
Car: 1990 240sx
Hey, Ive got the ultimate solution for you guys. Get the nismo mounts made for the CA18det from Courtesy. Theyre not on their website, you have to call them to place the order. The part numbers are 11210-RS520, and11220-RS520 i think. The CA mounts are about an inch lower and this should settle everyones problems. I installed these on my friends SR to lower the engine for better handling. They seem a little stiffer than the ones for the SR too, I think its because since its shorter, there is less to move around. Hopefully you guys are still paying attention to this thread.
Red coupe
Car: 92 Nissan 240sx Coupe
I am! Ill have to look into that for sure....any one else heard of this? if true it sounds awesome
180fan
Car: 89 fastback
I can personally vouch for the clearance with Cusco stb's and nismo mounts on both KA24E's and SR's.
