PEZi »
https://forums.nicoclub.com/pezi-u122065.html
Thu Mar 24, 2011 8:18 pm
Here's the scoop. I write this on behalf of my mom. She recently took her 2001 X-Terra to Woodmen Nissan in Colorado Springs, CO. She spent just a tad over $3,000 in much needed maintenance and other repairs. Her car was in need of a lot of things due to age, included was timing belt, water pump, brakes, transmission flush and spark plugs. Other things included (due to CEL's) New thermostat and knock sensor. I'm sure there was more stuff that I am forgetting, but let's move on.
The X-Terra ran 100% fine when we took it in, it simply needed a little work. Now that we have it back, it runs like complete s***! The idle is erratic, sometimes sitting at 1,500 rpm for no reason at all. Sometimes it will be completely fine, but not always. It also makes odd noises, of which are hard to really explain, but sound mostly like ping pong balls bouncing IN the valve train... WTF!? On top of this, the transmission now shifts odd. It was 100% smooth when we took it in, now it clunks on occasion when stopping for lights, like its grabbing downshifts for no reason and then letting them go. I really don't get it.
The biggest issue isn't that its running strange, though. The big problem is that it has become VERY thirsty. I haven't actually calculated it yet, but if I had to guess, we're not seeing over 14 MPG, and probably closer to 12. This is at least a 4 MPG loss, and I can only assume its related to what is going on here.
The guys at Woodmen Nissan claim that they cannot replicate the symptoms we are describing, which I call BS on because it does it far too often for us to say it would mysteriously be ok when its in their hands. I've grown tired of dealing with them.
Is there anything I should check? I plan on checking all vac lines this weekend, but other than that, I think they need to fix this problem on their own dime. This is not the first time one of our cars ran worse after taking it to them, and we will probably not be visiting them any time in the future.
Thanks for any help guys!
