yeah, I've limited connections to 200 or less via the torrent software and it still kills it. Otherwise it works great.PoorManQ45 wrote:Check out this page to see if your router is compatible. http://www.dd-wrt.com/site/support/router-databaseG router does fine if you are just surfing the internet. I only have a 40Mb service.
I had an issue with my LinkSys WRT54G when torrenting. What happened is that the NAT table was constantly at its limit. The refresh rate is a little too slow and the max connections is 512.
I flashed DDWRT sp24 mini to it and set the max connections to 2048. Fixed every single issue I ever had. There are a plethora of other options that you may be interested in, but it works right out of the gate if that's what you want...
I believe so, I pasted what it is into google and didn't come up with a whole lot on whether it's a N card or not, maybe you guys will have better luck since you might know where to look for the real complete specs, since the manufacturer doesn't give me much to work with on their site.AppleBonker wrote:Does your laptop have a Wireless N card?
Correct. In my case I do transfer large files between my desktop and my HT system so in that case N+ would be beneficial. Otherwise, from a network perspective, wireless G is rated to 54Mbps which is faster than most home-based network connections.MinisterofDOOM wrote:You can walk into pretty much any store and pick up a WRT54G right now. Easily one of the most commonly stocked routers in my experience. I'd say that qualifies as "current." And they have horrible lifespans.flohtingPoint wrote: "Any current one" doesn't include that. A G router is relatively archaic.
Like others have said, N is really unnecessary much of the time. Unless you're doing large file transfers within the same wireless network, you're not going to see any real performance benefits over G. Which is why, despite being older, G hasn't gone away.
Which is another consideration, signal degradation and response time. My wife's PC is on the 2nd floor and my router is in the basement. She connects at 54Mbps via wireless G but can only pull files at 1/2 the speed of my directly-connected system. If we assume N is stronger (we know it's wider) then there would be somewhat less of a data transfer delay due to slower response times.......maybeRCA wrote:From my experience N Draft has a much longer range than G
From what I can tell it supports N but people have lots of problems getting it connected at that speed. I saw one thread where someone had to change some specific router setting to connect and work at N, otherwise just lots of complaints.Chaotic_Warlord wrote:I believe so, I pasted what it is into google and didn't come up with a whole lot on whether it's a N card or not, maybe you guys will have better luck since you might know where to look for the real complete specs, since the manufacturer doesn't give me much to work with on their site.AppleBonker wrote:Does your laptop have a Wireless N card?
My laptop has this wireless card in it: Atheros AR5B91 Wireless Network Adapter
