NICO ECU UPDATE (some for sale, news/updates).
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
You can safely run a moderate amount of boost on the stock ECU.
Thtas what I would run. For boost, the stock fuel map is about what we want we just need to tweak timing so it doesnt detonate. You could probably run 6-8lbs on the stock ECU with race gas.
Thats exactly how robert made his experimental boost map. Stock fuel map with a similar timing map to a turbo car.
qsiguy
Car: 1994 Infiniti Q45 Turbo
Wow, that was a fast response! Thanks, I'll run OEM for now. If all goes well this week and next weekend, I'll be up and running....Getting exciting
elwesso
2007 BMW M Coupe
you definitely need to take a video. Im getting EXCITED!
apossiblehybrid
Car: 1994 Q45
will you be selling an nico ecus anytime soon?
dodiho
Car: 1996 I30 1999 Q45
Elwesso...you have helped me before...what is the difference between a ECU and a ECM? The tech in Austin Infiniti says I need a ECM for my auto '99Q.....is there a problem with reprogramming them once it is installed by me? I am thinking the two are the same.....thanks...Doug
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Th FSM uses ECU and ECM interchangeably.
No shop can program an OBD II OEM ECU. But neither will you need to if you install the correct one.
Q45tech
ODB2 can be totally or partially reflashed.......................the equivalent of reloading an entire operating system with a Consult II or III and a very very savvy expert technican.
Any tiny changes must be recompiled so that the hash code is equivalent to oem check digit code.................why aftermarkets skip low volume applications the software engineers to break encryption are costly.
