I bought RUSSELL SS lines and ATE SuperBlue DOT4 fluid for Layla, and she stops in about half the distance of Lola with stock brakes. Wehn I finally install my BEAUTIFUL Z32 brakes, slotted/drilled zinc plated rotors, SS lines, speed bleeders and DOT4 fluid, I expect to have much less brake fade, shorter stopping distances, and a MUCH firmer brale pedal. So far, I have $600 invested in the whole upgrade.ceningolmo wrote:I didn't replac my lines. Still running stock Q lines. Wes replaced his with stainless steel, but says he wishes he hadn't!
I would stick with stock unless you have a specific reason not too.
What brand slotted/drilled zinc plated rotors are you getting? And since you seem to be pleased with the RUSSELL SS lines and ATE SuperBlue DOT4 fluid, will you be using the same SS lines?Jeff Williams wrote: I bought RUSSELL SS lines and ATE SuperBlue DOT4 fluid for Layla, and she stops in about half the distance of Lola with stock brakes. Wehn I finally install my BEAUTIFUL Z32 brakes, slotted/drilled zinc plated rotors, SS lines, speed bleeders and DOT4 fluid, I expect to have much less brake fade, shorter stopping distances, and a MUCH firmer brale pedal. So far, I have $600 invested in the whole upgrade.
As far as the heat shields, use a cut-off wheel or grinder, don't use pliers or a hammer!
Pads from Joe $69+, rotors from nopionline.com $67 shipped, calipers from Napa $99 each (all prices are for fronts, not sure if I'm changin the rears yet).Flagship-Q wrote:Just wondering, where do you guys get the calipers and rotors from? Are they new or used? Thanks
Precisely! The tires are really the determining factor for cornering and braking performance.Q45tech wrote:"I bought RUSSELL SS lines and ATE SuperBlue DOT4 fluid for Layla, and she stops in about half the distance of Lola with stock brakes."
Since an oem braked Q with oem pads and oem rotors and oem tires was speced at 129 feet 60 to zero? A 1995 300zxtt stopped in 128 feet oem test.
Apples to apples longer than stock [single stop] braking distances are 90% tires and 10% pads........if you turn the ABS system Off you will see that stock brakes can lock the tires at 60 mph [if you push hard enough].
Most drivers cannot bring their leg up to power to exert 120 pounds, they are so use to typically exerting 40 pounds for a 0.3G stop at best.
Go to gym and set 120 pounds on leg machine for practice.
With a brand new correct tire the ABS systen should not cycle more than a few times in a panic stop, every cycle greatly extends the stopping distance.As the new correct tire ages [every thousand miles] the distances get longer and longer for every heat cycle.
Study the dry braking distances in Tire Rack test notice the wide variations from best [80 feet to worst 120feet] from 50 mph on BMW test cars
Since March of 2002, and have gotten the ABS to kick in on dry pavement with nice new Yoko's.elwesso wrote: Squeefoo has been using it that way for about 4 years or so as he told me.
Me too !! A MightyVac with the bottle is so easy -it's pitiful...elwesso wrote:also while im ranting..... I think speed bleeders are stupid.. I think speed bleeders are stupid..
Not as much as greater rotor mass and greater swept area, all other things being equal, which they never are.Jeff Williams wrote:To say that SS Lines don't make a difference in repeated braking or brake feel or even in the time between pressing on the pedal and caliper piston movement is not correct, in my opinion.
AGREED.maxnix wrote:Not as much as greater rotor mass and greater swept area, all other things being equal, which they never are.
Wes, do you have any pics of modified banjo fittings?elwesso wrote:Jeff... when you get in there, you will find that the fittings will want to hit things on the suspension... Your proabbly right too about the lines, i just dont think they make that big of a difference..... Regardless, i will not recommend the 240 conversion lines to other owners.. if they gotta have steel lines, id say get Q45 lines and cut down the bolt..... I dont see why the banjo fittings are a big deal, they use banjo fittings on almost all nissans.....! Squeefoo has been using it that way for about 4 years or so as he told me.
