RobertsnewQ »
https://forums.nicoclub.com/robertsnewq-u29366.html
Thu Jan 12, 2006 7:42 pm
Z32 rotors are 2mm thicker (30mm vs. 28mm) and the calipers are four-piston fixed aluminum calipers vs. two-piston sliding iron calipers. Many advantages:
1. thicker, heavier rotors absorb more heat before pad temps become critical, therefore resist fade better.2. Four-piston calipers do not flex as much as sliding calipers, giving better pedal feel (less wasted pedal travel)3. Aluminum calipers are lighter than iron, therefore less unsprung weight (and better handling over bumps). *cancelled out by heavier rotor.4. Caliper rebuild kits, pads, rotors are cheaper than stock Q parts.5. Aluminum calipers radiate heat from the brake fluid faster than iron, reducing peak and average brake fluid temps.6. Better selection of pad compounds (similar Sumitomo calipers used by Nissan, Toyota, Subaru, Mazda.)7. Aluminum calipers do not corrode as badly as iron (anodized bores) and therefore should last longer.
There are disadvantages:1. Poor wheel clearance - requires the right 16" wheels, or many 17" or 18" wheels.2. LESS brake force multiplication at the front, resulting in more rear brake bias (not so bad) and harder brake pedal (not so bad either)
As for the R32 brakes, there are two skyline brake setups:1. GTS-T: 280mm X 30 mm front & vented rear (same as late Z32)2. GT-R: 300mm X 32mm front & vented rear (NOT same as Z32)
Many ebay sellers PURPOSEFULLY do not mention which R32 skyline the brakes are from in order to sucker people into paying lots of money for what are basically Z32 brakes. Be VERY careful. The rotors, calipers and other parts are all available through NISMO in the US. THey're expensive, but not too expensive - $100 each for rotors and $125 each for calipers.
FWIW There are also three Z32 setups:280mm X 26mm front rotors & aluminum calipers (same as Mazda RX-7 88-90??)280mm X 30mm front rotors & aluminum calipers (same as Subaru 97-00 USDM 2.5RS & 2006-up USDM WRX NOT STi)280mm X 30mm front rotors & IRON calipers (same as Toyota 4Runner)
Now, if you don't want to mess with Z32 brakes, Y33 brakes work too. They use the SAME calipers as G50, but different caliper brackets, and 300mm X 28mm rotors. I THINK they will fit under 15" wheels, but I'm not sure. The Y33 rotors are cheaper than G50 rotors.
