Well, the Viper 5900 has been discontinued for around 2 years now. It was replaced by the 5901. However, if you don't want remote start, then you don't want the 5901. The 5002 is the alarm only version of the 5900, but is only 1/4 mile range. There is also a replacement coming out for the 5002, which uses the new LCD remotes that are found with the 5901. However, it will also only be 1/4 mile. It will be more expensive than the 5002 though. The new unit will be a Viper 3303 and will be $209 shipped. So if you have to have the SST(1 mile range), then you would have to go with a remote start/alarm.... the 5901 or 5902. Those can be found here:
zerothread?id=384467
Here is a pic of the new Viper 3303:
Modified by Broadfield at 4:16 PM 2/19/2010
