TeflonG35 wrote:My advice is that you should only experiment on a car you can afford to live with it being broken down. That is very cheap for a turbo kit. I wouldn't gamble on my g35 with it. If it was a cheap honda or some beater, then who cares?
Unsafe boost can rape your car......
TeflonG35 wrote:You don't know the quality of these parts. The intercooler could be crap and not properly cool. The piping could be cheap and no be able to handle the boost. The boost controller might be crap. Lots of factors that could be bad. I really don't want to see you waste $800. Nor do i want you to blow up your car from something failing. You don't own a honda. G35s are expensive. It will cost alot more then the cost of that turbo to fix.
gwoods wrote:You'd be better off peicing together your own turbo kit.
You need a way to manage detonation that that kit doesn't have. I don't know what your G's compression ratio is but the 07+ is 11-1 so adding much boost is not possible.
If your serious about boost buy a used motor and start the tear down and rebuild with forged parts and lower compression ratio.
WDRacing wrote:That kit is crap for a few reasons. The add is full of lies and propaganda, the parts are NOT designed well at all even at a glance and the "parts list" is nowhere near complete enough to be considered universal in anything but the weakest of terms. A turbo by itself is "universal"...that doesn't mean it will work well or even at all.
Lies I noticed right off: Turbo compressor will NOT support 1200whp...utter crap. They use words like Type, meaning it's kinda like a proven part, but not quite. They use the Acro "JDM" and they don't use proper grammar or correct English in the ad. I dunno about you, but that doesn't give me a warm fuzzy about the company.
Design flaws: Inter cooler piping isn't designed to hold boost. The BOV is a fake, known to suffer from leaks. The wastegate is also a knockoff with known failures in the past. When the wastegate fails, the boost isn't controlled causing an overboost condition leading to detonation which leads to at least one cylinder going lean enough to destroy a piston ring land at the very least. At worse you destroy more then one piston, scratch the cylinder walls enough to require a complete overhaul.
Any "kit" that is under a $1000 is made up of weak materials and incomplete at best. This is a great example of what not to buy.
WD
Do you drag race? I thought you were into twisties. I would assume that S/C would give you better response than T/C, and it is more suitable than T/C for your needs. Have you ever driven a car with S/C or turbo? Max power is one thing, but torque and horse power curve is more important, don't you think?Jacko3 wrote:Cost to power ratio seems somewhat higher than that of the turbo.
The turbo is better then the centrifugal supercharger is almost every way. Torque and horsepower come from being on boost for more of the usable rpm band. The supercharger does not hit full boost until you reach your maximum rpm. The turbo does not heat the air any more then the s/c. The turbocharged car can be driven without boosting any time you want since the turbo's boost threshold is based on load not rpm, the s/c however will be making some boost all day. Causing worse gas mileage and more wear on the motor. Which is the exact opposite of what most people assume. The turbo produces "some" back pressure, which is immediately negated by the parasitic loss the s/c puts on the motor since it's belt driven. A properly sized turbo can produce almost immediate full boost when WOT is applied yet still be driven in traffic off boost...NO s/c except for a roots type will produce immediate boost. To adjust the boost pressure of the turbo you turn a knob inside the car...while driving if you want to. To change the boost on the s/c you need to swap pulleys. The turbo has no belt slippage.Minmey15 wrote:
I would use Nitrous at the track I suppose. But I wouldn't use it for spool, mostly just to get out of the whole and run a 2 stage so I can blast through the lights once I actually have traction.TeflonG35 wrote:Or you can compensate for the lag with a little Nitrous oxide. They have turbo kits where the nitrous(WOT of course) is only on until max boost is achieved. So you can get those bigger, meaner turbos without having to worry about lag. Not to mention if you go turbo you get to get a sweet sounding BOV. (I do know Centrifugal superchargers can get BOVs as well.)
Ive heard many stories of people going supercharger, aren't happy with the power and eventually going turbo. Not just with our cars.
