WDRacing wrote:
The turbo is better then the centrifugal supercharger is almost every way. Torque and horsepower come from being on boost for more of the usable rpm band. The supercharger does not hit full boost until you reach your maximum rpm. The turbo does not heat the air any more then the s/c. The turbocharged car can be driven without boosting any time you want since the turbo's boost threshold is based on load not rpm, the s/c however will be making some boost all day. Causing worse gas mileage and more wear on the motor. Which is the exact opposite of what most people assume. The turbo produces "some" back pressure, which is immediately negated by the parasitic loss the s/c puts on the motor since it's belt driven. A properly sized turbo can produce almost immediate full boost when WOT is applied yet still be driven in traffic off boost...NO s/c except for a roots type will produce immediate boost. To adjust the boost pressure of the turbo you turn a knob inside the car...while driving if you want to. To change the boost on the s/c you need to swap pulleys. The turbo has no belt slippage.
Almost all information that says the s/c is better then the turbo is largely produced from uninformed opinions scattered across the Internet.
Is the s/c bad...hell no. Boost in all forms is the way to go. NA = gay but the turbo IS the better choice if you want to make an informed opinion.
WD
That is very interesting and totally educational. Actually, I have never owned any S/C system. Every car I'had has been turbo charged. But I did test drive some cars that had S/C. One car I remember cearly is S15, and its turbo charger was swapped to S/C. At the time, I had S15 myself, and I couldn't believe how responsive it was. Of course, mine was producing more max power, but S/C system was just so responsive to throttle. Am I the only one who thinks S/C is more responsive than T/C? FYI, my S15 had stock turbocharger, which is pretty small.
Since my G35 is totally stock and have no clue of S/C and T/C for G35, is the T/C damage the engine that much more thn S/C? I always figured and was taught that any modification you do to the car shortens car's life. And turbo's heat and all that would cause more damage than S/C. I guess there are pros and cons?
