New TT Z (load of pictures)
hydrocet420
Car: 1990 300zx TT
nice z bro!! yeah for some reason my z wants to grind going into fourth gear for some reason although all the other gears are straight!!!
derekinthez
Car: Red 91-300zx 2+2 Red 94zxtt Super Black 2003 350z 2001 S-10 2001 GSXR 1000 2003 Yamaha YZ450F
NICE BUY. Looks very good for the year and mileage.
Loki
Car: 1994 Nissan 240SX Convertible
2010 Toyota FJ Cruiser
2001 Ford F-150 SVT Lightning
Aww, you're living my dream, going from a wrecked 240 vert to a turbo 300z. I still drool over those cars when i see them. Looks good!
Zwicked
Car: 1990 300 ZX tt, 1990 240SX
Is the controller inside the cabin missing for the SBC? What about the electronic box that connectors between the controller and the solenoid, is it there? It would probably be in the floor near the ECU or in behind the radio maybe.It doesn't appear to be there though as the solenoid is not plugged into anything. That red plug should have a harness going to the electronic brain module.I'd be surprised if you can boost over whatever the waste gates spring is, probably 7 psi or less as without the controller it'll default to spring setting.The solenoid does not store the info for boost settings so unhooking your battery will have no effect.Seeing as they plumbing is all there, you'd probably be better off just buying a whole new Blitz SBC-EBC and installing it. I bought a Blitz SBC-IDiii and love it.
Decent looking car...welcome!
Modified by Zwicked at 8:30 AM 1/14/2008
merlin3
Car: 1990 300zx 2+2 twin turbo , 2003 350z greddy twin turbo
be careful with whatever you're boosting, I can see the vacuum lines teed together obviously for a boost controller but you say you don't have the controller so might want to get that taken care of.
otto_3478s
Car: 94 AlTiMa + 94 tT 300 zX
Zwicked wrote:Is the controller inside the cabin missing for the SBC? What about the electronic box that connectors between the controller and the solenoid, is it there? It would probably be in the floor near the ECU or in behind the radio maybe.It doesn't appear to be there though as the solenoid is not plugged into anything. That red plug should have a harness going to the electronic brain module.I'd be surprised if you can boost over whatever the waste gates spring is, probably 7 psi or less as without the controller it'll default to spring setting.The solenoid does not store the info for boost settings so unhooking your battery will have no effect.Seeing as they plumbing is all there, you'd probably be better off just buying a whole new Blitz SBC-EBC and installing it. I bought a Blitz SBC-IDiii and love it.
Ok thanks for the info. Ill do some more research on it and see what I can come up with. I've searched the car for the controller and other components but came up empty handed.
Loki wrote:Aww, you're living my dream, going from a wrecked 240 vert to a turbo 300z. I still drool over those cars when i see them. Looks good!
Yeha I still cant believe that this car is mine... HUGE upgrade!!
merlin3 wrote:be careful with whatever you're boosting, I can see the vacuum lines teed together obviously for a boost controller but you say you don't have the controller so might want to get that taken care of.
So would I just be better off removing it untill I can get a complete system?
Zwicked
Without looking over the EBC installation on how it was done and if the factory system was abandoned or incorporated, it's a tough call what to do other than say replace it with a new one.What boost pressures have you been hitting so far?
otto_3478s
Zwicked wrote:Without looking over the EBC installation on how it was done and if the factory system was abandoned or incorporated, it's a tough call what to do other than say replace it with a new one.What boost pressures have you been hitting so far?
Good call I'll have to investigate more on this issue. The factory boost gauge reads about 8 psi.
scjustin
looks good!
NismoJ30
Car: 1994 Acura Integra
1992 Nissan 300ZX TT
Real sharp Z!!! Good Luck
otto_3478s
Thanks guys!!!
Dittoz7
Car: 1997 2f0WtY SE!
Damn Looking Clean!But Gotta Get Rids Of The Konigs...Fast.To Bad About The Vert Tho.At Least You Kept It In The Nissan Family!
otto_3478s
Yeah new wheels are in the works, and hell yeah, Nissan for life!!!
