Zippy69 wrote:Forgot to mention. Swapped out ecu with one from my 93 and would only idle, when you gave it gas it would stall. What up wit dat?
Nevermind then......
You need to run a code check after you give it a chance to run a while with a dohc ecu.
With the dohc ecu what you do is turn the knob fully clockwise to diag. mode with the key on, engine off. After a second, turn it back fully counter clockwise. The ecu should then start blinking the LED with the code. Long pulses are the 10's, short pulses are the 1's. If you get 5 long blinks and then 5 short, that is a code 55, which means all is good. If you get any other codes, take note.
