whoareu wrote:This is in response to the question about the rollcage + soft top.
So your saying it does fit the soft top? If so, can this rollbar be purchased online, or is it going to need to be specially made? and if so what should i expect to pay for that kind of work. but i have been searhing my A** off trying to find a rollcage or harness bar that comes premade and will fit the vert.
Yes, mine did fit with the soft top. If you look at the pictures on the first page of this post, you will see the cages I built in both convertibles. Since I am 6'4", I needed a much higher cage and I had to do a little more grinding on my softtop frame to get it to fit. It still fit fine though and operated fine. The other vert was for my friend who is over a foot shorter than me and his top closed without any modifications since I was able to make his cage shorter. FRSPORT made a roll bar for the vert, but it welds to the rear box between the rear strut towers. It isn't the safest spot in my opinion. If you are looking to be able to pass tech at a few drifing events, then the FRsport roll bar should suffice. If you want to get a full cage for the vert, it has to be custom.
