petercscherer wrote:Definitely appears to be a vacuum leak then. I also own an '82 and had the exact same problems. I tested it by spraying brake-cleaner around the base of the carb, any changes in idle is evidence of a leak around that gasket. I have a Weber installed on mine and simply filing the surface of the intake and the adapter plate fixed my issues. Yours could be as simple as a cracked vacuum line though. If I were you, I'd look into removing all the unnecessary vacuum and emissions lines/equipment; depending on where you live, these smog-parts won't matter and you can also boost your engine performance and tuneability at the same time. Regarding the patch panels, another guess might be a local junkyard or pick-n-pull. Where are you located? I might have a few suggestions.
Cheers,
Peter
petercscherer wrote:Alrighty, I'm not the supreme expert on explaining this process, but here's a few pics of what can be removed.
The "tower" in the front is part of the fuel-shut-off (an emissions/safety device from the 80's), it can be removed if you also pull the vacuum pump behind the carb. They are all part of the same system.
Everything that is circled was removed when I went through the engine. Those three caps on the carburetor were already that way when I got the truck and may actually be originally done at the factory.
Anyways, I'll include some other pics from other threads here to show more views of what can be plugged or bypassed.
The following thread was SUPER helpful for me and is also the source of several of the above images.
vacuum-line-removal-t556957.html
Good luck!
~Peter
I will if i can do it from my phone ill figure it out this weekpetercscherer wrote:No problem, it's a real joy to help out other owners. Glad you're up-and-running! Post some pics when you get a chance!
~Peter
petercscherer wrote:You'll probably end up leaning it out and then compensating with the fast-idle screw; timing is possible, but it wouldn't explain the change in idle speeds. Z-motors don't have Engine Control Units (ECU) like modern cars do, so once the timing is set, the only thing that changes is the vacuum advance. Running rich at idle is going to increase your idle-RPMs, it will also cause weird behavior once the engine is hot and can even cause vapor-lock in the carb.
~Peter
