New to Nissan Swapping
pissedoffsol
Car: Honda's, Turbos, Skylines... not necessarliy in that order
Hello everyone- I'm new.
[img ] NEWBIE.GIF[/ img]
I know I know I know...:)
I've been in the Honda Camp for a long time- Swapping motors is nothing new to me- hell, I run a Honda motor swap website (see sig).
I feel like I'm starting all over again- In fact, I am... I'm eyeing a 92' 240 hatch/notch whatever its called (not the coupe).
I have a bunch of generic questions- YES I searched... but I don't know key terms to search for really- so it turned useless.
OBD - does Nissan follow the same obd rules (<91 = 0; 92-95 = 1; 96-98 = 2a; 99> = 2b).If not, what OBD is the 92 240sx?
s13 swap-I'm looking at the 'red top'. How do i know if my car has the LSD or not (other than physically looking inside).Does an s15 6-speed bolt up to an s13?what about mounts- ive heard stock k24de mounts are the same- is this true?Wires- I read on SCC about their sylvia swap, and they mention wires being a biotch. Does anyone have a template, or something to go buy? Does it differ per ECU? per obd?
As you can tell- I want to be sure I get the rigth stuff. I've done tons of research over the past few days, but its just that- DAYS. I have 3 years of Honda tuning behind me... and I feel like a virgin :) some one Tap my a$$!! haha
Thanks in advance guys/gals
-B:help
I H8 UR DSM
pissedoffsol wrote:Hello everyone- I'm new.
-B:help
nissan has obd1 and obd2
afaik, all redtops are obd1
lsd pumpkin has an orange sticker on the outside of the pumpkin...which is a visual distinction
you can make the S15 transmission work with modifications, but as far as i know, it wont 'bolt up' and work fully without work....but yes, you can make it work.
stock mounts are 'same', pretty much, they actually arent the same, jdm ones are stiffer, and the ka ones are preloaded on one side, but yes, you can use them, although i would recommend using the jdm ones or a set of Nismo aftermarket mounts.
wiring is pretty straight forward if you get a swap with the uncut wiring harness, and have knowledge working with cars...if the harness is cut, then wiring is a *****.
when i got my motor from Jeff Holden, i got the FSM on CD from them...most of the basic wiring is on heavythrottle.com, otherwise it was found in that disk.
good luck
jesse
I H8 UR DSM
ps, is that your crx? My friend Charlie Lore runs pro all motor class in his white civic hatch (11.5), i dont know if you are familiar with him, or his and bobs site at http://www.b20vtec.com
later
pissedoffsol
No - not my car-- thats Cory Thompson's car... Hes our dragger guy... gave him a little feature- but he never gave me any info to put up there! haha.
I dont know the guy you mention either
Anyway-
obd 1- Good thing :)knock sensors? do the sr20's have them?
What is that disk? it came with your swap? would you 'share' that info with me? :) please? :)
Who is jeff holden?
I'm no master mechanic- but I can get things done if i have the tools usually. If not, I have friends who are and have the tools.
What needs to be changed to get the 6 speed to work, do you know?Also, I'm interested in gear ratios of all the boxes- anyone have a link?
Thanks for the reply dude-
I H8 UR DSM
well i know there were probs people came accross with the s15 trranny's like, speed sensors, stuff like that, i know it has been done though, and i think heavythrottle might have that info...
Jeff Holden and Yuri ___ run Heavythrottle.com , real big and popular in the 240 scene with a great reputation.
yea, if i have that cd still, i would send it to you or something, i have to look for it though, i have no idea where it might be....but like i said, i think we only refered to it once, the wiring is pretty straight forward......just get an uncut harness with the motor
sorry for short response, in a rush...be back later, lol
Daunttless
Yes, they have knock sensors.
The Disk is just a copy of the SR20DET FSM, most people to do their wiring compare the SR20DET FSM with the 240SX FSM, and line the wires up. Other people use resources like http://www.srswap.com
Jeff Holden is the co-owner of Heavy Throttle, ( hopefully I didn't mess that up, sorry Yuri : ), they provide engines and installations.
The transmission mount will need to be changed, as will the driveshaft, rear end, and speed sensor. Most people don't use the 6 speed because, a) its extremely difficult to buy a 6 speed without a S15, and b) its generally considered weaker than the 5 speed, because it has 6 gears in the same allotted space as the 5 speed has 5 gears, this leads to less material per gear. A lot of people in Japan rip their 6 speeds out and put in 5 speeds, I don't know why you want it...
Gear Ratios:5 Speed3.321 - 1st 1.902 - 2nd 1.308 - 3rd 1.000 - 4th 0.759 - 5th3.382 - Rev 4.083 - Final
6 Speed3.626 - 1st 2.200 - 2nd 1.541 - 3rd 1.213 - 4th 1.000 - 5th 0.767 - 6th3.437 - Rev 3.692 - Final
I have a lot of additional information at my website, as does Heavy Throttle at theirs, either http://www.srswap.com or http://www.heavythrottle.com , mine can be reached thru the link in my name, Jesse has also provided a link to my site. Enjoy your day!
pissedoffsol
cool- no prob. thanks man.
After Dark have a good rep with uncut harnesses?
Daunttless
we won't be importing any incomplete engines for sale, maybe a couple for parts or in rare circumstances where someone needs a block, but we only sell 100% complete.
pissedoffsol
ok seeing those ratios makes me want to puke!
5th gear at 1:1 christ!
scratching the 6 spd idea :) besides, longer gears are better for boost :)
FSM = Factory service manual correct? Does helminc.com make a nissan manual? <-- heads there now... cuz they make kick-*** honda ones.
I see you have a black top Jesse (that's your name right?)why did you choose that over the red top?
pissedoffsol
Dauntless-- did you see my other post? http://www.nissaninfiniticlub....=5266last post...
Quote »Damnit- why do you have to be in Iowa???
After I pick up my 240 (hopefully next week) I'm sure we will be in touch.
Do you do discounts? I mean- buying an sr20 swap with a bunch of options and a sylvia conversion all at once = $$$$$$$. Would you cut a deal on a big order like that?
I'm getting out of the honda sceene... and have a **** load of parts, swaps, and cars to get rid of- adn then, its buying time
Let me know.
[/quote]
Daunttless
Yeah, check out my response. : )
pissedoffsol
right on- just saw it...
I H8 UR DSM
pissedoffsol wrote:I see you have a black top Jesse (that's your name right?)why did you choose that over the red top?
well i was originally getting a redtop, but there werent as available as now, so it was a long wait.....then someone ended up not being able to pay for the motor, and they offered it to me, since he was aware i was looking at the time....i was able to get a very new, and low milage (19,000miles) motor, which for me was real nice, almost like buying a used 98 car, lol.....i liked the idea of the supposed "reworked" or whatever ecu, but really it was a year, and milage issue...now i like having something a little rarer...soon it will be special, i think a candy apple grean top SR20det, hehe.......
yes im jesse.
laterjesse
pissedoffsol
if you had to do it again- which would you choose? red or black?what is the better motor- money not being a factor, and why
Daunttless
they're both basically the same, especially as soon as you start modifying
I H8 UR DSM
it depends...if i was doing it again, and wanted to have a fully built motor, all internal work, and standalone ecu, id get a redtop, if i was just throwing the motor in stock, id get a blacktop...thats just me though : )
jesse
pissedoffsol
whats the bottom end good for stock? I'm going to up the boost- and stand alone it, but im probably not oging to tear the bottome end down...i just want a fast street car-- 13s....
I H8 UR DSM
about 400-450whp....id say 400-425whp to be safe.....13's you dont have to touch the motor....you can run 12's without having to touch the inside of the motor (may want to consider headgasket)
jesse
Daunttless
I usually suggest that people don't exceed 350rwhp if its going to be even remotely close to a daily driven car. Obviously you want it to last and thers no reason to put undue stress. Plus, every motor has a little different tolerances. : )
pissedoffsol
id do a headgasket and studs, but i really don't feel like ripping apart yet ANOTHER motor this year. man if you could only see my garage... boxes of ****e everywhere.
12's sound good to me :)
now- to unload this Honda thinghaha
Daunttless
put it in sport compact, everyone knows that if a car is it sport compact its worth 10 times as much as it was before the article. : )
pissedoffsol
lol- naw- not the car.. I'm thinking of keeping it as a beater. haha- parts are what I need to get rid of.. but before i do any of that, i want to make sure this 240 im eying is going to go through. I'm going to NY to test drive it in 2 weeks... so the wait continues.
pissedoffsol
SCC would never have it... I only have 1 sticker
I H8 UR DSM
well if you would consider a nice NOSSSSSSS sticker you could cut it....
that car doesnt look fast : ) i like it, lol
I H8 UR DSM
ps, beautiful house
pissedoffsol
Not my house-Car is slow.
lol
any other observations :)
I H8 UR DSM
yea, you need a fresh air freshner, and you might wanna close your windows, it might rain ; )
pissedoffsol
hehe- yeah, good call... more like SNOW.its freakin cold lately
ItzGenX
Car: Smoke Purple 95' S14.5. Powered by the "Iron Man".
So daunt, if we buy more then just a motor from you, you would slightly discount it? I was lookin to order a motorset and 97-98 front end conversion from you at the same time.
pissedoffsol
he said no
