New to ca's - just did swap. pics and some questions
jjwilks240
Car: cars
just did a dohc ka swap to ca18det swap in 17 hours
included pulling everything from the clippullin the kaquick clean of the engine baythen take a power nap for three hoursend up with this 17 hours later
this started at about 8:00pm friday night, ended about 8pm sat night
i deducted 3hours for sleep and 4 hours for going to eat at a restourant and taking the transmission off the ca and trying to put my ka clutch in but didnt work so we deducted that because it really wasnt nessesary
somehow between 8pm to 9:30am i sourced a downpipe, j pipe, hks bov, and boost gague and testpipe.
i dont know why it takes you guys so long to do your stupid swaps
i would never have been able to do this with the help of lots of people though.
**next day***tonight i took it for a nice drive
in 5th at 3000rpm the thing goes 95kmph. It has ****ty gearing. I did manage to boost to 12.5 psi in 4th and fifth. Thing runs really rich still.still have that whistling when i get into boost, and no its not the spoolupgona re-do the vacume lines on the weekend.
also need a sohc throttle body cause the dohc is too long and we had to make a custom mount for now
ANYONE HAVE ANY IDEAS WHAT WOULD BE CAUSING MY WHISTLING?
daniel577h
Car: rx7
looks good, i hope mine runs soon stupid CA
Dattebayo
I think its because the gerbil on the wheel is not so areodynamic...
lol j/k dude!
vis213
12.5 psi isnt giving you much benefit at all with the stock CA turbo
put on a SR T25 then try 12 psi
Nunook
congrats for the swap!
nice BOV.
OKCA18DET
i want to marry that girl gettin her hands dirtywhats her name :-D
c-rad
Car: 1991 Nissan 240SX w/CA18DET
OKCA18DET wrote:i want to marry that girl gettin her hands dirtywhats her name :-D
Mike? LOL.....
boost_boy
Perv . Excellent job with your conversion, no go blow it up like most everyone else .
Dee
rico05
Car: 1992 RMS13 w/ CA18DET
Is your BOV asjusted properly? I know that mine whistles sometimes because it always leaks (damn recurric required ARC).
No offense, but your little comment on how long it takes all of us to get our "stupid" CA swaps done is not entirely accurate. I did mine in about the time it took you and ran off the first crank
biosehnsucht
c-rad wrote:Mike? LOL.....
Actually assuming that IS her own uniform I'd guess Mika :P You can't tell from the angle waht the 4th letter is really..
jjwilks240
Car: cars
her names rena, she has a kouki s14, chuki s13 and 90 na 300zx
OKCA18DET
tell her to PM me im in love
WeldingHank
Car: 1989 240sx CA18DET
strange, i am doing about 120KPH at 3500RPM.
RMiller
Car: BBQing
Quote »in 5th at 3000rpm the thing goes 95kmph. It has ****ty gearing.[/quote]Sounds like you're using the KA differential with the CA speed sensor. You're going faster than your speedo says.
Whistling=BOV too loose. Tighten it.
Modified by RMiller at 11:45 AM 4/1/2005
dvd
what did you mean the ka clutch didnt work? i thought it did if u took out one of the pins on the flywheel?
NeedCAforS13
Car: CA swapped S13 coupe
and i'll say it again... KA clutch does work. I've used two of them now. Honestly its so straightforward I don't understand how people have trouble with it!
Sean
cadet
Car: 89 s13 coupe
whistling= boost leak somewhere, probably.
WeldingHank
yeah, i'm using a DOHC Centerforce dual friction KA clutch. pulled out one of the alignment pins, went on like butter.
jjwilks240
Car: cars
yeah we pulled a pin also
im just gona sell it and once my clutch goes ill get a better one
float_6969
Hank, how do you like that clutch? I've got a SPEC Stage III and I'm not real happy with it. It grips alright, but I don't like the pedal feel and it didn't last very long last time either.
cadet
Car: 89 s13 coupe
you can weld aluminum, just have to have aluminum rod.. and generally be welding to aluminum, though there are exceptions.
Did you guys ever think about how much more you have to slip the clutch on a low torque engine like the ca as compared to the ka? I know my clutch takes a lot more abuse now than it did on my ka...
float_6969
Yea, I've noticed. A lightweight flywheel makes it worse. I killed it like 3 times last night trying to take off. I've got to wind it up higher now than before. It revs so much free'er now though...
jjwilks240
Car: cars
yeh its totaly weird, its like launch, no power till boost. then once boost hits wheels start to spin haha.
cadet
Car: 89 s13 coupe
sounds like a boost leak, thats my problem too. Hoping to solve it today though...
rico05
I hate trying to drive my car from a stop when cold. My uber clutch (still don't know the brand haha) has zero feel cold, and when warm, HATES HATES HATES to be slipped. But damn if she don't hold. I ahd thought about getting a JUN flywheel, but F-that.
float_6969
Hey jjwilks240, Do you still have the clip? If so, can I have your Vacuum resivoir? It's over on what would be the passenger side in the US. Behind the strut tower.
Neejay
jjwilks240 wrote:i dont know why it takes you guys so long to do your stupid swaps
Well, I would assume it has to do with tools, resources, and experience.
BTW, how much did you get your clip for?
NeedCAforS13
Neejay wrote:Well, I would assume it has to do with tools, resources, and experience.
thats 100% true. I could get on here and ask how the hell it took YOU 17 hours to do your stupid swap (especially with all that help you had). Put yourself in the position of someone who has no real previous car experience, and don't kid yourself. This isn't a hard swap for someone with the right tools and experience. A clean chassis (like yours) helps out alot too (less rusted bolts and dirty stuff).
Now go replace a cracked piston in an afternoon (cough... done it ) and I'll be more impressed! Not to downplay your achievement, but try being a little more subtle in your wording of things. It could easily piss people off, you came accross as arrogant.
Sean
Nismo_Freak
Car: 89 Nissan 240SX
jjwilks240 wrote:yeh its totaly weird, its like launch, no power till boost. then once boost hits wheels start to spin haha.
Honestly thats why I went with an SR in my S14, but I still like the CA.
One might find it's way into an S13 here shortly dunno.
float_6969
You can get the CA to launch with power just fine! You've just got to work the motor a little bit. I rarely get beaten on a launch with my CA. But I also rev it to 4K and slip the clutch like crazy. The CA just requires a little finesse to drive, thats all..
