I
tollboothwilley wrote:I'd change out your spark plugs if you haven't.
Might think about cleaning the MAF...it could be reading and not throwing a code but it could be dirty. Get some CRC MAF cleaner. make sure you don't spray it too close. Stay at least 12in away.
at ~50K miles all the plugs I've ever pulled from a G35 are no longer gapped properly. Could be your cause.
The G35X does have a 3.5 FD gearing ratio. Most other 5ATs have 3.3 so you will by default get lower gas mileage than most 5AT, but you should be on par with other G35X's...~18-22 MPG seems pretty normal.
I will probably do that. Also, I am going to get new rear tires so I will include an oil change. Just dont think it was done properly. Last tank net 15.65 MPG. a touch better.
