A fiberglass box would be more effective at saving space, but it would weigh about the same. The problem is, a fiberglass box would take about 10x as long to build and would cost around $300 for supplies. As for weight, I can take the box out of the trunk myself without too much trouble, so I'd guess and say that it weighs about 120lbs. The woofer is 53, and I used a little over 1 sheet of 3/4in MDF that weighs 60lbs per sheet.ScottJackson wrote:I tell ya, there sure is a lot better audio stuff now than 10 years ago when I was last into that stuff. Seems there's a lot more heavy hitting type subs now and amps are just getting cheaper and cheaper. Too bad I don't care much for that stuff anymore. Anyway, cool thread so far. Would there have been much weight savings if the enclosure would have been made of fiberglass? I have always wanted to try building a big bandpass out of the trunk. I figure you can make a divider to separate the front of the trunk from the back, mount the sub in it, and have the back part of it be the sealed part of the enclosure. Then have a rectangular port tube come down and over the gas tank on the other side of the divider. I suppose it'd need a strong seal around the trunk lid and all the sheet metal would need reinforcing/dampening. But it wouldn't take up much trunk space to do it that way. Would that be feasible at all?
That was one of my concerns with your setup. The OEM alternator only supplies a little more juice than the car needs. It looks like you're gonna handle that with the rewind, but you might end up cooking it anyway with that kind of power draw!nimbyfaygo wrote:I'll be getting the alternator rewound at a local shop, and I'll be getting a second battery for rear. Its pretty insane the amount of voltage drop I'm getting, I'm being careful with the volume knob, only cranking it for short periods of time. I don't want to mess up any electronics by starving them.
Also can anyone tell me the factory amperage output for the stock alt on a 94? Its seems real low, especially at idle. I have a clamp on current gauge, but its at my dads house.
Technically you already have a fourth order enclosure (Actually the order changes with your windows being open or closed) But you are venting the woofers output into the trunk which vents (Or Loads) into the cabin through your "Vent" in the rear deck (Bandpass one) and then vents again if your windows are down to the outside world (Bandpass Two). It's part of what is called the "transfer function" of the car. You would do well to re-inforce the trunk lid with more then Dynamat. I would try to bet some 1/2 to 3/4 MDF attached to the trunk lid and every panel in the trunk that vibrates. When your trunk lid moves like you have described, it wastes the woofers energy both in moving the lid and in the pressure that could be leaking out of the seal. Great job so far, are you going to follow the bass up with some well designed kick panels and maybe some 6X9 or 8" mid bass drivers in the doors? I am also curious (You may have discussed this, not sure) about your battery and charging system. Are you upgrading besides the Bat cap? You might be able to get a higher output alternator off of a V8 truck application that was used for emergency type duty (Police, US Forest, etc etc).nimbyfaygo wrote:A fiberglass box would be more effective at saving space, but it would weigh about the same. The problem is, a fiberglass box would take about 10x as long to build and would cost around $300 for supplies. As for weight, I can take the box out of the trunk myself without too much trouble, so I'd guess and say that it weighs about 120lbs. The woofer is 53, and I used a little over 1 sheet of 3/4in MDF that weighs 60lbs per sheet.
Now you could build your trunk into a 4th order bandpass but there would be tons of problems with that. First it would be nearly impossible to measure the correct airspace. You could fill your entire trunk with packing peanuts, and then see how many cubic feet they occupied. That would be a pretty accurate way, just messy.
Bandpass's are very sensitive regarding airspace. Your tuning freq would change whenever you went shopping! LOL Your fuel tank would be Inside the ported chamber . Have you ever heard a speaker box that was made out of 1/4in plywood? Well thats probably close to the same way your trunk would sound. Unless you went crazy with dampening materials.
If you could over come all these problems you'd would have a very unique setup that would be able to house probably four 12's easy.
