naed240sx »
https://forums.nicoclub.com/naed240sx-u28231.html
Fri Jan 04, 2008 4:30 pm
Ok man, here's the deal.
I'm going to assume that you have an S14, otherwise trying the R33 cables would be pretty stupid. If you do have an S14, and they don't fit right, well then they don't fit right. The problem is when people say things are "straight bolt on" they aren't always. The most important thing is that you secure the brackets closest to the part of the ebrake cables that attaches to the T bar. The brackets farther down that are supposed to attach to the subframe are not neccesary. You can just let them dangle. This will create a bit more of a spongy feel with the ebrake handle, but the ebrake will still be plenty strong. This is how my car is set up, although I had to make custom brackets, whereas your front brackets will probably bolt right up.
As for the extra length, just make sure you get the other end attached to your ebrake drums, and if you are worried about the cable moving around too much, ziptie it to the subframe. done and done.
