Are your hubs in spec? Very little over OEM specified variance can incur rapid degradation of rotor performance.GreenQ45a wrote:If this set of OEM rotors is what Infiniti says is Q45 worthy I dont agree.
These rotors should not need to be recut after less then a month.
It could be the Type of pad that you are using. Are you using the same type on both your Maxima and your Q?GreenQ45a wrote:I would be willing to blame the ware on the calipers.
My maxima used the same set of Cross Drilled for 2 years and never needed to be cut. No warping no glazing.
This routine might be why. You probably never got the brakes to seat properly (300 miles of non-severe application after initial OEM cycling) since you came down the mountain the day after you installed them, I bet.GreenQ45a wrote:I live in the mountains of NM just above Albuquerque.I drive 25 Miles down the mountian and 25 back up every day.The pads just glaze to easy. I don't care about the cost of pads or cutting rotors.
Yes, including the Stillen J30 rear and associated hardware.GreenQ45a wrote:"Joe can get both with the Stillen Brembo rotors."Is that front and rear?I wonder what Joe would charge.
I think one of us should check out a pair or Xdrilled.
How do you measure how hot your rotors get?Q45tech wrote:Try the Axxis Ultimates from Tirerack or who ever if your rotors go above 700F.
Um..... I think you're forgetting what I replaced my brakes with. Even if my brakes are not as good as OEM (Can't tell the difference), I can replace them for FREE. That's the glory of Autozone's Lifetime warranty.AZhitman wrote:Good brake stuff is not cheap, but done properly will save $ in the long run.
Um..... are you saying that there is something wrong with stuff made in China?AZhitman wrote:I have the SP Performance rotors (made in Italy, not China or Taiwan) in drilled, slotted or both.
Most people would not notice a 60-0 change. I don't think many people go around driving at 60MPH and then slam on the brakes and come to a complete stop. Usually, minor changes are made, say 60 to 45 MPH.Q45tech wrote:If the new 90Q stopped in 129 feet would 150-155 feet from 60 mph satisfy most?
Yes! They are not as heavy (poor quality cast iron material) and do not handle heat well. They are more likely to crack or "warp". IMHO, this would be a classic case of "penny-wise, pound-foolish" if you do not choose to use good rotors and good pads and keep your brake system in proper working order. Proper braking can make the difference between a minor and major accident.PoorManQ45 wrote:Um..... are you saying that there is something wrong with stuff made in China?
Most people would notice when they hit something!PoorManQ45 wrote:Most people would not notice a 60-0 change. I don't think many people go around driving at 60MPH and then slam on the brakes and come to a complete stop.
Dennis: What is the change in distance vs time between OEM brakes and aftermarket Brakes when accelerating from 60 to 45 mph? Is it even possible to measure this?
