Currently we do not. Lead time is 2-3 weeks IIRC from the time you place your order.kclo4 wrote:So this is a little late, but I had some questions.
For one, do you have any stock now? My at least 2 of my 4 GAB's are blown and I decided to go with coilovers. For 2, would it be possible to get the price you initially posted instead of the $1107? This is going to make me super broke, especially after ordering the brake lines, speed bleeders and pads from you guys last week(and the rotors/calipers).
Yes, you can replace the shocks individually.kclo4 wrote:Third, somebody asked this but I didn't see an answer. If just one of the shocks get blown, can the body be replaced individually?
Hard to say as ride is percieved differently by different people. It will be noticeable but I don't personally think it's overwealming. You can ask a few members on the board how the ride quality is for a better assesment.kclo4 wrote:Fourth, I have GAB super HP shocks and Eibach prokit springs now, do you know how rough the KTS ride will be in comparison?
Honestly it really depends on your area. Rougher the roads, the faster any shock will wear out. I'd overhaul them about once every 2 years for normal usage.kclo4 wrote:Fifth, how much punishment can these coilovers take from daily driving? How much force does it take to blow one of these? Pot hole at speed? Speed bump at speed?
I will be autocrossing, lapping the track, and possibly drifting, so I presume these should be great.
Us then you... we run them through a quality check and repackage them.kclo4 wrote:Sounds reasnoble enough, I know some of that stuff is hard to gauge untill you actually buy the things and use them for a while.
Expect another order from me early next week...
One other question though. Do these hit you guys then me, or are they drop shipped directly too me?
Yep.gabossie wrote:I just actually ordered mine today as well as a few other goodies. Can't wait. Was that you that I talked to today Alan?
Yeah you should be able to drop them a good amount without adj. the preload.kclo4 wrote:Couple questions. Should I be able to get a 1" drop without messing with the spring preload much?
Adjusting the spring rate somewhat.kclo4 wrote:What advantages are there to having spring pre load or not if my desired ride height can be achieved without preloading the spring?
Just make them tight, you don't have to go nuts on them with a breaker bar or anything.kclo4 wrote:How much should I crank on the locking rings to be safe?
You can generally eye-ball camber and toe to get it somewhat straight.kclo4 wrote:Any other initial setup tips so it doesn't jack the handling before I can get it to the race alignment shop?
I'm sorry but Alex's comments are unwarranted and biased.coldasice wrote:Sorry for reviving a 3 month old thread but I just wanted to bring up something regarding the SPL KTS coilovers and thought that this was the most appropriate thread to post in rather than creating a new one.
I have been looking into coilovers for a while now and I've finally saved up to be able to purchase some. The SPL's seem the best coilovers for someone like me who is on a tight budget but I wanted to know if this accusation about the SPL parts are true.
Driftex from http://www.drifting.com/forums...ber=2
Is there really any validity to what this person is posting?
*EDIT*Here's the actual post Alex makes regarding SPLhttp://www.drifting.com/forums...er=26
Yes these are still available at http://www.splparts.comDelphic Reason wrote:Ok, I know this is probably extremely too late. However, I am really interested in purchasing a set for my S13... Are there any still available?...
Yepnismofly wrote:going back to the Alex thing, ive heard quite a few negative comments about Battle Version quality, but none whatsover about SPL...
old thread Alan but are you planning on running these, or a version of them, on your NASA car?
They will be well suited for that spring rate, and thats the reason why Tein and SPL offer only small variations in spring rate.phuphyter wrote:Since this thread is up again, I have a question about the dampening on KTS coilovers. I read in another thread that SPL can have them ordered with +/- 1kg/mm spring rates from the standard 8/6).
Would the KTS coilovers with 7/5 kg/mm spring rates ever be over-dampened? I'm thinking of buying a set for a street/ocassional autocross/ daily driver.
They would be overdampened in my opinion.Bronze MFP wrote:+1 for KTS and SPL. Don't know how long i've been running the coils, but I love them. I broke a mounting stud off of one of the front camber plats, and was shipped a new stud via 2day air so my car would be ready for the weekend. SPL has awesome customer service.
Alan, in your opinion would a 6/4 spring rate be too far off for the dampers? I ordered a set of 4kg/mm springs from SPL, but don't know if I really want to install them. It would mostly be for comfort since my car is a DD. Thanks
