I am a first-time Infiniti owner. Infact, a first-time anything-other-than-Ford buyer. Today I bought a used 2012 M37x in Black Obsidian with 84,000 miles on the clock. It appears to be in good shape, but I have some questions so I can make sure she's tip-top.
1. Do the 2012 models need the ECM to be flashed for the 7AT shifting issues?
2. Is there a software update for the nav/radio on the 2012s to fix issues with Bluetooth being funky? (I remember reading something about it, but forget the years).
3. Is your brake pedal squishy? Mine is and I'm not sure if it's normal for this car or if it's in need of a brake bleed - the brake master cylinder reservoir has fresh clean fluid in it so maybe there's air in it. Is Pennzoil or similar DOT 4 synthetic okay? Recommendations? Any gotchas with flushing with the ABS?
4. At 84k miles, should I assume all other fluids and filters (except engine oil) are old and replace them all? (ATF, Power Steering, Coolant) Again, any gotchas with the replacement of these fluids?
5. Suspension - I'm not sure if it's because it's at 84k, but the suspension feels softer than I expected...but I mostly test drove Gs. How often do shocks/springs need replacing?
6. What things should I check to make sure they're up to snuff that commonly go bad or wear?
I am coming from a 2006 Mercury Grand Marquis that I put alot of work into for a quality audio system that looked near-stock, modified and tuned the engine and transmission, stiffened the suspension, and upped the rear axle ratio from 2.73 to 3.73 with a LSD. Was fun to corner fast and get two tire fires at stop lights. Sorry to see it go thanks to the fault of another moron on the road...
