Here is a question, how it the pivot ball for the clutch fork in the transmission? Was there a lot of play it in? If that was good, I would not stress too much until after you get the master and slave cylinder.RobbieDobbie29 wrote:And yes there is about a 1/4 inch of play in the pedal before any resistance is felt. I also confirmed this by pressing it in with my hand.
Nope, just cause its a PITA to get to. As long as it doesn't leak, just let it be. No differences between the engines except the Japanese didn't really take care of their cars, for the most part. Most of the time the JDM motors are beaten pretty bad, lack oil changes, coolant in the system, they tend to use just water. Plain water rust the hell out of the system. If the car has been running good, I wouldn't stress too much. Just keep taking care of it and hopefully nothing will come of it.RobbieDobbie29 wrote:It is a JDM engine according to the PO..... 45k on the ticker. Any differences between the USDM engine and the JDM one? So......the oil pressure gauge works........do I need to do anything about this one?
Thanks for the quick and dirty version!! Haha every once in a while I do some research on manual transmissions, I think if I actually had one to play with I would learn about it in no time. I deffinitely wouldn't want to learn on a 300zx though I would get some beater HondaMr. McGinley- The clutch system is pretty basic, pedal press the master, which then pushes fluid to the slave, slave engages and pushes the fork which then moves on the pivot ball and pushes the throw out bearing onto the pressure plate then release from the friction disc. When you let go, the pressure plate sandwiches the friction disc to the flywheel. This then makes the the power go from the trans to the driveshaft. The friction disc rides on the transmission output shaft and spins with the trans. The flywheel spins with the engine.
LOLWater in the coolant system.......well that explains the Fukashima scenario.......
That took me a minute to get it, when it finally hit, I chuckled a little, lol. Somedays, I am a little slow.t.mcginley.jr wrote:Nah I knew what you meant, I was LOLing because of the Fukashima part (because the Japanese only use water for coolant, not actual coolant)
There has to be air in the system, or getting into the system, for it to still slip with all those new parts
