RobbieDobbie29 wrote:Well the idle drops from 8-850 to like 600 or so. On the little pops, it almost sounds like a injector issue to me. But thats when I noticed the vacuum change so i was concerned about it. I'm wondering why the car is on safety boost, and it has a MBC on it. I opened the MBC to look for a boost change, but nothing happened according to the gauge. So, I closed it back up and it's the same boost pressure. I don't mind it boosting low for now as long as it ain't a critical issue. I don't want to blow up the car or melt it down...
Do a boost leak test. You can either buy or make a tester yourself. Making one is pretty easy, I think it cost me $5.00 to make and helped me find mine and made a world of difference.
If he has a MBC, I would find out if he disconnected the factory setup, which it sounds like he did. I also would highly recommend getting an EBC, think of it as a safety measure. Did you try turning it both ways? It may not be hooked up, it should go to both wastegate solenoids. Check to make sure its hooked up to a vac source as well, if it is, the MBC could be the issue. If he bypassed the factory settings, you will not be on safety boost at all. If no boost controller is hooked up, the wastegates automatically open at 6 or 7, as long as a vac source it hooked up. Mine opened at 7.
