breadbox wrote:this is a nice read before I start rebuilding, my RB20 in the future, I am now going to try and get everything tested, and not just assume it works. I hope the coils makes everything happy.
Hey thanks!
I think I am officially allowed to laugh when someone pops up saying something like "Yeah I just bought a RB25 from jankyjunkengines.com for $1500 and I installed it why doesnt it run?"
Once I get this thing running I'm considering doing a writeup on it. I've noticed threads and stickies that explain what's needed to install an RB, and the minimum things that should be replaced before install (belts hoses plugs wear parts etc) but I haven't really found anything that really details how to make sure everything works on it. Aside from the FSM. And thats a PITA. So I might just condense all that crap into a "things you should check on your RB and how to do it" article.
Also I've found WAY too many threads where they give every miniscule detail there is when describing the problem, but then when they fix the problem, they get as vague as humanly possible. "Yeah my symptoms are (millions of details) - oh I fixed it, it was electrical."
electrical WHAT?!
Where was it, what was it, what was wrong with it, how did you fix it? And thus the thread becomes useless.
As for mine... The coils helped, now it's easier to get going, but it still wants to die out. While pulling off sensor connectors, I found that if I disconnect the tps AND maf, it fires right up (and idles poorly), but if I connect either of them, it won't start or idle (MAF was good, TPS was good-ish, I'll be retesting TPS). I also found that my VCT solenoid closes as soon as the engine spins up even a little bit (even if I slowly spin the CAS by hand), and I'm pretty sure it shouldn't (iirc VCT isn't supposed to kick on till like ~1200 rpm, and certainly shouldn't be on at idle, let alone when someone spins the cas slowly at maybe 100 rpm).
And if I understand cam timing correctly, having the intake cam advanced during startup or idle could cause all kinds of problems, including many of the ones I've been having. If I understand cam timing correctly, having the intake cam advanced w/o the timing advanced would open and close the intake valves too soon, causing it to draw less air, and spraying fuel at a closing valve. In theory, of course
Off I go, to do mechanical type things
