New member and new vert =]
Nategreat923
Car: 1992 240sx "Sil-Vert"
Hey, my names Nate and Im 16 and I bought a vert a while back and JUST stumbled apon this awesome site. Just thought I'd say hi and let you all know that Im here!
Now for some pics
And soon to come! (yes I have the fronts too haha)
I use http://www.northwestnissans.com and have been a member of that site for quite a while. I am looking forward to using this site! thanks for looking!
Modified by Nategreat923 at 4:19 PM 5/17/2008
S13xCrazy
Car: 1993 240sx Vert, 1993 BMW 325i, 1993 Honda CBR F2, 1998 Infiniti Q45,
Looks great! Have fun with her and be safe! I can see you are new to driving, so don't let your lead foot get the best of you!
white90esex
Car: 90 240sx
90 Q45
12 Titan Pro4x
06 xB
nice. Im jelous
Nategreat923
thanks a lot. I definetly wont let the lead foot get the best of me with this car, because verts are so rare and this is too special to demolish or beat on. I do have a question though. I have an auto as you can see, and after driving for a while when I stop (at a light or stop sign) it starts to idle really rough and it even died once. I was told that the strainer in the transmission needs to be cleaned, is this true? thanks in advance
red_vert
Car: 1994 Nissan 240SX vert
sweet car! pics and everything nice.!
jspec603
Car: 92 verrrrrrrrrrrrrrrrrrrrrrrrrrrrrrt
Nice ride! Good to see yet another vert around here.
S13xCrazy
Nategreat923 wrote:thanks a lot. I definetly wont let the lead foot get the best of me with this car, because verts are so rare and this is too special to demolish or beat on. I do have a question though. I have an auto as you can see, and after driving for a while when I stop (at a light or stop sign) it starts to idle really rough and it even died once. I was told that the strainer in the transmission needs to be cleaned, is this true? thanks in advance
I find this very hard to believe. I would look at other things first. I had a similar issue with my Coupe.
Do the RPM's drop at all (anywhere below 800 or so?) and then want to bog down and off? Or is this happening at a higher RPM?
What happened in my coupe was that I would come to a stop and my rpm's would drop low enough to where the car would want to turn off.As a quick fix, I adjusted the idle just a little bit higher and I never had the problem again.
Hope this helps
Nategreat923
Hope this helps
it happens at a stop and it drops below 800 far enough for it to actually die. Im taking it into a transmission shop for a free diagnosis
Loki
Car: 1994 Nissan 240SX Convertible
2010 Toyota FJ Cruiser
2001 Ford F-150 SVT Lightning
Good to see another Silvert in the NICO family. Welcome and enjoy your stay
-RJ-
Car: S13 Convertible, 99 Frontier, 03 Sportage, 96 Protege
lucky lucky kid it has the silvia front already lol
welcome
Nategreat923
thanks a ton for all the comments!
Bryant0086
Car: 1989 Nissan pickup 2004 Nissan Quest SE 1992 240SX vert
Super clean vert !! Good luck getting the idle problem repaired. It doesn't sound like anything serious though.
Bryant
Topless_92
Car: 92 Nissan 240sx Convertible
Nice vert. Welcome to NICO
DeXteR
Car: '14 Nissan Titan Pro4X
'05 Nissan Xterra OR
'92 Nissan 300ZX Slicktop
'94 Nissan Sentra RS Rally Car
I'm going to go out on a limb here and say that your idle problem is not at all related to the transmission whatsoever.
You've got some vacuum or fuel related issue going on. You should check to make sure all your vacuum lines are hooked up. Does the car run rich when this happens?
Anyways, welcome aboard. That's a nice looking vert you've got there. Thanks for not making me bust your balls for pictures.
94_240sx
Car: 94_240SX
Nategreat923 wrote:it happens at a stop and it drops below 800 far enough for it to actually die. Im taking it into a transmission shop for a free diagnosis
When you're looking at the engine on the left side right next to the fan, you will see a little hose from intake pipe going under the intake manifold. Disconnect it, spray half can of carb cleaner in there and start the car. It should clean up IACV and see what happens. Also search IACV(Idle Air Control Valve) on nico and read some threads.
And, like dexter said transmission has nothing to do with this.
jamesblonde82
Car: 1992 Nissan 240SX convertible RIP 5/10/07
1993 Nissan 240SX convertible
actually guys, on the auto, the torque converter can go bad in many ways and could cause it to pull on the engine hard after it warms up. so saying it's def not the transmission could make him overlook something.
nategreat... do you notice that the torque converter locks after it shifts into 4th on the highway? does it lock really rough, or not lock at all? these could also be signs that tell you theres something wrong with that. but check the simpler things first like dex and 94 said. if its your TC (torque converter) then you gotta lower the trans and replace it. perfect time to go with a 5sp swap
onosqv
Car: '92 240sx Vert
Nategreat923 wrote:And soon to come! (yes I have the rears too haha)
Those ARE the rears buddy .
Clean lookin vert, me likes!
Nategreat923
thanks for all the suggestions, im gunna check them out pretty soon when the rain stops.and about the wrong suspention pic, sorry Photobucket confused me, i took the wrong link and thought it was the rears
Kristine
Car: 1992 Toyota Paseo
1997 Nissan Altima
wow...
I'm so jealous! you have the silvia front.
Nategreat923
thought Id share this with you. Last friday weather was 80 degrees and sun shine.Today...
Influenced
s13 front end looks great!
Kristine
1997 Nissan Altima
mmm you should consider a 5 speed swap and a 5 lug conversion
Nategreat923
well Im debating a) keeping this stock while getting a beater hatch to drift b) silvia front clip and swapping the SR in with the RHD swap or c) 5 speed swap with a KA24DE-T
YOUNG240SX
Car: 90 hatch
-RJ- wrote:lucky lucky kid it has the silvia front already lol
welcome
very nice silvia front looks great
B-Boy DuB-L
Car: 1993 Nissan 240SX
It could be a fuel injector. HAHA i actually just replaced one of mine because the same thing was happening. wen i would stop it would idle rough sometimes stall or felt like it was about to stall. You could check it wit a multimeter, check ohms on injector so be between 9 and 14 i believe, and then use a noid light to check if it is getting any electrical current to the injector. It may be one bad cylinder,sumtin wit compression, U may have a vacuum leak, or may just need to adjust the idle. Good luck finding wuts wrong and fixing it.
BTW if your wondering i changed the injector today and WOW wut a ****ing difference!!!!
Kristine
1997 Nissan Altima
Nategreat923 wrote:well Im debating a) keeping this stock while getting a beater hatch to drift b) silvia front clip and swapping the SR in with the RHD swap or c) 5 speed swap with a KA24DE-T
C) 5 speed swap with the KA-T!
... and a roll cage
hehe, that's just my opinion.
Nategreat923
... and a roll cage
alright so i decided to go KA-T, so here are the parts waiting to be put on the vert
ishkabibble
Car: 1992 Nissan NX2000 hardtop
1993 Nissan NX2000 t-top
1997 Infiniti I30t
Did you fix your rough idle?
Nategreat923
haha no, i wish, but we think its the injectors, so when we turbo it im gunna buy stock SR20 370cc injectors and hope/ pray that it fixes it. And I just picked that TD04 up today for 50$
ishkabibble
1997 Infiniti I30t
Did you check/clean the IACV?
