Anyways, this post in a matter of speaking is a continuation of my original post that was guaging interest in a new MAF setup for KA(D)E(T) guys. The original post can be found here:http://www.nissaninfiniticlub....55794
Well, I have been workin hours here and there when I can sneak away from school or work or on the weekends and I have made some serious progress. For all intents and purposes the hardware side is completely done, and about 90% of the software side is complete as well.
I currently have my 95 240sx running on the GM MAF perfectly.. I'll bet once I remove the unused nissan maf from the intake I will probably even pick up a few horse... =] and even more if I tune my car with the MAFT (GM MAF Translator).
I know a few of you wanted to see a picture of the MAF, and this is one I took before I put it on my car... I would also like to add that the GM MAF fit perfectly on the stock throttle body! Although I would suggest a blow through setup. I will do an attachment a few times so the maf picture will be in one of them.
I have a lot of the software interface built, and it displays and datalogs all current values from the MAFT. The MAFT has:- 1 Global (+- 50%) adjustment- 14 point adjustable (+- 20%) in 500 rpm increments from 0 to 6500+- Reads and logs: RPM, AFL (for you SAFC guys) - essentially the MAF 0-5v output signal, O2 Voltage (will read/log 0-1v or 0-5v), and throttle position.- Can set or retrieve the fuel settings from the MAFT- Can save or load these settings to local files on the computer. So you can save a pump gas map, race gas map, etc.- Has a basic feaure for injector correction, that does the math for you for a bigger injector (runs a safe tune).I will include some pictures of the software interface after this, but I am at school and not the car so obviously all the values will be 0 since I'm not connected, but at least you can see the interface.
SO, this is where I am going.. I currently have it running on my relatively stock s14. I am testing it on Jake's (Top street 240) turbo s13 (has 250-300 to the wheels), hopefully this weekend. I would also like to know if there is anyone in the Milwaukee, WI area that has a 91-94 s13 that I can just throw the MAFT on to verify the RPM and MAF signals on.
Finally, I know that many of you had voiced some opinions that you may want a speed density system (i.e. MAP sensor). This is still a possibility that I can do if enough people are interested. I would like to add though that if you do speed density you will almost surely need to tune the car because EVERYONES VE is much different from the next person. I can set it for a generally close tune but you will need to fine tune. Where as the GM MAF is a mass air system thus all tuning should be almost exact from one car to the next.. with less fine tuning needed.
Let me know what you guys think and if you have any questions... Hoping to have this thing available early next month!
Murray
