Chezedik, All good questions that I don't know if I have addressed...
- Ok, first as far as system requirements for your laptop... funny enough I honestly don't know. I am trying to keep it pretty basic so that it can be run on an older machine with windows 95 or windows 98 on it. I will have a little more info on that once I can check to see how it does on windows 98 (maybe later today).
- Yes you can run the MAF essentially WHEREVER you want. You can put it after the BOV (and before the TB) on turbo charged applications and then vent your BOV to the atmosphere with ZERO problems. You can run it draw through right at the filter if you would like. Whatever floats your boat, it will all generate the same signal in the end (gotta love MAF
- I admit timing control would be awesome. However I do want everyone to realize this IS still a piggyback, and I am definately not here to compete directly with the AEM. However my unit is what... less than a 1/4 the cost, and thats WITH the MAF. I will tell you all now, things may be looking up for the timing control, I have a good idea on how to get a boost master style timing retard function implemented. My idea would be this: Have it 2D adjustable MAFT voltage vs. Timing retard.. Also do note this would be a timing RETARD ONLY, that retards off the stock timing map. If you want to advance it (not that most people do) you would have to advance the base timing lets say 5 degrees, then you could pick and choose where to retard the timing back to normal.*I will begin to start playing with the timing retard idea, after I complete the 3D fuel version* So I will probably release the fuel controller + MAFT version first. Don't worry though because I can always upgrade your unit if you send it to me and pay the difference in price between the 2 units.
- Tuning/Datalogging stuff.. Honestly for now, Im gonna have to keep it basically the way it is, later on I may add a feature that will datalog Injector pulse. For now its: RPM, MAF%, O2 volts (will LOG narrowband or wideband), and Throttle. I could potentially add the other things you said to a different version, but based on my current hardware design, having all those parameters is kind of out of the question.But
Not sure what you meant by "flashed" so I will answer both possibilities: - Yes the units can be flashed for upgrades, however you will need to send me it... - What I think you were asking was if the laptop was needed to run the MAFT.. The answer to that is NO WAY
. All you need the laptop for is to datalog or to change the fuel settings (later on ignition settings) if need be. Once you change them they are stored internally in the ECU in EEPROM. If you lose your fuel settings on the laptop its not a big deal either the MAFT controller automatically sends the fuel settings from the MAFT to the laptop everytime it connects.
I really could use an S14 tester honestly, but if you are interested and have a working KAT feel free to email me.
Murray
