''you do not need to remove the steering wheel or mess with the airbag to install the steering wheel adapter!kuhan wrote:Yup. It does seem intimidating. Especially when you need to remove the steering wheel and dealing with the airbag as well.
I might deal with this last or forget about it since I don't want to mess around with airbag.
Doc, I have the Z. I found a thread that shows a 350z owner had to remove the steering wheel in order to install the interface, but this was a 04 or 05 model. I wonder if the newer Z is different or that that guy have a base Z without steering wheel controls.rjdmmfl1 wrote:''you do not need to remove the steering wheel or mess with the airbag to install the steering wheel adapter!
I would say that this install ranks about a 2/10 on difficulty! The steering wheel interface would rank at about an 8/10. I've done a few before, and for some reason, I couldn't get Alientracker's to work in his car... but I'm pretty sure that is the result of a bad connection somewhere! You have to use really good 22 Gauge 2 taps to contact those skinny *** factory wires on the factory harness!headhunt3r wrote:How was the install for this deck? I'm still tossed in the air about doing this myself, or paying like 250 to get everything installed professionally... My friend's not too comfortable installing this with me, but I don't see anything that could be overly difficult about this install. I was thinking worse comes to worse I could just leave out the steering wheel adapter to make the install easier for myself.
Looking for some advice from anyone who's done this install! My friend used to work for CarTunes, but that was back in the day, and he's just scared of breaking something in my car cuz it's fairly new. I have only had experience with installing a deck in my old car, 02 Sentra, and that was a piece of cake. Should I tackle this myself? Or should I just pay up and get it done professionally...
BTW, anyone have any idea about the green wire that you need to ground in order to watch video's while the car is in motion? I assume the black wire (ground) is not big enough for the green to hop along on.
Modified by headhunt3r at 2:28 PM 2/10/2009
The only thing i could not get to work is this I hooked it up (twice, to make sure it's not bad connection) and unit (5120) doesn't respond to brightness knob on the dash!! GRRR!!! Or is it supposed to do something totally different hahahaa!!rjdmmfl1 wrote:---T-tap the orange/white illumination wire on the kenwood harness to the red/yellow wire on the factory harness
no, it doesn't respond to the brightness know, it responds to the status of your headlights. When your headlights turn on, the unit can be set to automatically dim. Or you can sync the dim function to that of the navigation unit, so that when the navigation is set to dim, the monitor brigtness will slightly dim also! I hope this makes sense!Vital wrote:
I believe it relays hot, it can be set to do a pulse, or continuous on switch!kuhan wrote:Doc,
Do you know if the two relays on DDX812/DNX8120 switch ground or hot?There is only 1 wire for each relay so I'm not sure what the unit is actually switching. I'm planning to control my foot well blue leds. Thanks
I'll answer this since Kuhan answered the ground question,headhunt3r wrote:
1. I've purchased the trim piece from Nissan already for the factory look, but that's only the outside piece. I noticed that the Metra kit has interior pieces that hold the deck in place. Do I need this? Or can I reuse the brace that inside already after I remove the factory deck. -Basically, do I need the Metra kit if I already have the outter trim piece?
Thank you both kuhan and Doc for the information, you guys are great.
well, the gap that Applebonker was speaking of deals with trying to use the facory nav double din unit with an aftermarket deck.headhunt3r wrote:I'm assuming the gap is going to be quite worse than this?
http://forums.altimas.org/zerothread?id=355852
I've got the non-climate control as well, and I just took out my deck + OEM double din kit, and I think I see the gap too, but I'm just not sure how much it should stick out (will give the gap a better look if it didn't stick out as far as I can push it while not installed). If I have to use a Metra kit in its entirety, then I'm going to have to decide whether i want to keep this deck or get one that'll fit nicer w/ the OEM... The Metra just looks too hideously cheap (And I'm not feeling the overlays either )
Ahhh this is causing more grief than I want I think I'm going to try out the weird ugly gap with the OEM just because I think I'd handle that better than the cheap ugly Metra piece...
nope, not in the Altimas.. we need an adapter... and the blue wire connects to the blue ant wire on the kenwood adapter..kuhan wrote:Doesn't your OEM antenna plug right into the Kenwood female adapter?
You can't beat the refurbished price on those DDX812's. Make sure you get a 2-yr Square Trade Warranty with it, it's worth it. NOTE: The warranty will start 60 days after your purchase (for refurbished item).LeGates wrote:Well I finally bought something. I got a ddx812 refurbished off of ebay today and plan on getting the nav module as well. I have sat back and read a lot of everyone's post and have learned a ton. Wish me luck on the install. Everything is on order. Kuhan, the audio set looks cool. I may just end up mimicing it for my car. Doc and apple seem to know their ****.
Biggest downfall of the kenwood units is that they don't play video through the USB.. onlu music files... however, I play .avi file on my kenwood... it may be how your disc is encoded! that's the only thing i can think ofheadhunt3r wrote:Question about video's on this deck. The manual says that *.avi's are playable extensions, but I've tried both an avi file on a USB and also on a DVD-R, and neither of them worked. I've tried a control of a real DVD disc, and that seemed to work fine. Has anyone tried the USB + avi combo? Or the burned DVD's?
