Chappy »
https://forums.nicoclub.com/chappy-u54842.html
Sun Jan 21, 2007 4:08 am
Bought the 114K 95 J30 for my son back in Oct for $3800. He put 7,000 miles on it before he gave it back to me.
Since then:
Tires: $509Battery: $91Stereo: $416Timing belt, water pump, tensioner, all drive belts, fuel pump removal and install , thermostsat replacement, transmission flush and fill $1,268...
Total: $6,084
I think I'll just live with the remaining issues:1) Non-op sunroof and rear windows2) ABS light is on but brakes seem to work fine. My mechanic thinks its likely a sensor. 3) Leather wear on the driver side door panel. 4) Fuel gauge does not work ~ the boy ran the tank dry x2 likely screwing the fuel sending unit?
How am I doing with repairs !
Can anyone clue me in on the engineering of the gas tank sitting behind the rear seat? Seems counter-intuitive. As an aside my son installed a 600w amp among other stereo bling-bling into the trunk and wired the ground to the fuel pump!!! He pushed so much power through the amp that it melted the ground wire to the fuel pump, very scary stuff.
On the timing belt etc repair: The tensioner was toast, the belt could have come off at anytime. With 122K on the belt it was in decent shape ~ some spider-web cracking beginning on the backside. My wrench of 15 years was impressed with the build on the engine.
