You don't need a code checker to check for codes on your ecu. Your ecu's codes can be read by merely turning your ignition to on and with your ecu already accessible, turn the dial that close the yellow and red lights clockwise until you see the two blink 3 times; then quickly turn the dial back before the 3 flash cycle ends and the fourth one begins. Count the # of flashes for the red light then the green light and let us know what the flashes are so someone cn give you codes if they're any. Oh yeah, like some of the guys say, riding around without a filter over your AFM will give you more issues than you really need.8ggalant wrote:thanks everyone...ill start by gettin a filter and adapter. also i dont have a "code-checker" (cant remember what ther called)...anyone local have one i can use- Caz maybe...Thanks for all the input fella's ill keep you all informed
thanks for the link caz
Modified by 8ggalant at 12:33 PM 2/24/2005
Your issue is more than likely around your afm, but what concerned me is what you said about your rpm. If it's flickering sporatically as you rev it up, then you more than likely have an ignition leak or bad CAS (Which I seriously doubt). Or it could just be the issues with your afm getting too much air. I've done it before and the car went ballistic. If you have your afm too close to the turbocharger and have no bov, you will have some issues as well.8ggalant wrote:k ill go out there and do that now...thanks boost
btw filter is on order and will be here in a few days
SO TRUE! when I first put the motor in the car, I didn't have the intake pipe, so I just attached the maf directly to the turbo, and my car ran like chit! Even with a 6 inch section of straight pipe on there it didn't run nearly as well as with my new stock intake elbow... gotta get the maf a little ways away from the turbo for it to read properlyboost_boy wrote: If you have your afm too close to the turbocharger and have no bov, you will have some issues as well.
Your ecu is self-diagnosing, so it monitors its own critical components. The CAS is a very critical component and if the ecu had picked-up an irregular signal, your ecu would display a code. Code 55 means your cars components are all responding during role call, so you are issue free for the moment when it comes to critical components.8ggalant wrote:ok well thats good to here...hopefully its not hte cas...if it is how would i test that?? and as far as the distance the maf is from the turbo its on the stock turbo to maf pipe(rubber pipe).. but yea the filter will be here monday or tuesday ...got an apexi univeral....and ill make a bracket/brace while the car is sitting.
one more thing my brother told me that he "HEARD" /some one told him when he had his ca's that you could reset the ecu by unplugging it for a period of time and plugging it back in...since it already said all is well should i attempt this or just leave well enuf alone...thanks for the help everyone...ill let u know how its running when i get the filter in teh mail...thanks again
kevin
