NEW issues
8ggalant
Car: nissan cefiro
thanks ill try that now and post back what happens...
8ggalant
Car: nissan cefiro
ok...car did the exact same thing...
when you turn it to on...i can here the fuel pump on ...pressurizes the system..then it stops...then i try to start it and it cranks and cranks but wont start....also i noticed that if i tap the gas a few times it will stutter some more like it wants to start and the rpm's will rise to about 900-1k (i stopped then)...so yea...ive had my nose in the fsm for the past two days but its rainin sumthin nasty over here so i havent been able to work on it (well it wasnt yesterday i just didnt get a chance to go out and mess w/ it)...
so does any of this sound familiar....help is GREATLY appreciated...
f s t caz
Car: VG30ET D21 Extended Cab Pickup
did you look at the plugs when you pulled them for the compression test? if you ever need another part to test, just let me know. I'll search thru my piles of parts for what you need.
8ggalant
Car: nissan cefiro
f s t caz wrote:did you look at the plugs when you pulled them for the compression test? if you ever need another part to test, just let me know. I'll search thru my piles of parts for what you need.
yea they were black....looked bad so i replaced them..then after sum research and cleaning i found out they were fine lol...
but yea its about time for me to pull em and clean em again...its supposed to be dry tomorrow so ill be out there workin on it...ill keep everyone updated..
droopy_map
Car: 1990 200sx
float_6969 wrote:Try unpluggin the MAFS completely. If it will start then (it may not run well) then you know it's isolated to the MAFS or a vac. leak. If it still doesn't start, then we'll have to look elsewhere.
That should help isolating the problem indeed, had the same problem recently, and the vacuum leak was located along the intake piping. Was actually the hose that allowed the car to trottle the was torn - was almost totally disconnected.
8ggalant
Car: nissan cefiro
ok checked for spark...i have none in the first cylinder, barely any in the second cylinder, and PLENTY in the last two...also pulled the plugs to clean them and they were wet from fuel so im SURE i have fuel...also someone asked me where the cas was positioned...(if the bolts were in the middle or not), the bolts are all the way to the right...i didnt try adjusting it to get the car to start seeing as i was missing spark from 1 (well 2) cylinders...so what are your thoughts...u think the two cylinders getting not efuff/NO spark is why it wont start...also as far as the cas/timing it ran fine that way be4 (doesnt mean it was right)...i dont have a timing light..im gonna try to get one tomorrow...SO...anyone have sum COILPACKS
boost_boy
8ggalant wrote:ok checked for spark...i have none in the first cylinder, barely any in the second cylinder, and PLENTY in the last two...also pulled the plugs to clean them and they were wet from fuel so im SURE i have fuel...also someone asked me where the cas was positioned...(if the bolts were in the middle or not), the bolts are all the way to the right...i didnt try adjusting it to get the car to start seeing as i was missing spark from 1 (well 2) cylinders...so what are your thoughts...u think the two cylinders getting not efuff/NO spark is why it wont start...also as far as the cas/timing it ran fine that way be4 (doesnt mean it was right)...i dont have a timing light..im gonna try to get one tomorrow...SO...anyone have sum COILPACKS
Sounds like a ground issue, but then again, that just plain sounds weird to me. I would be wary of the igniter as well.
Dee
8ggalant
Car: nissan cefiro
well i checked all the grounds and they were fine except two...2 of them were not connected to anything :? ...so i grounded them to metal and it didnt make a difference
8ggalant
Car: nissan cefiro
ok well just to update everyone on the @$$ beating im getting by the 240 ....so ive been reading the fsm and learning alot but still havent remedied my problem...so i know dee said it seemed to be a ground issue so i scoured the engine bay looking for em...and found none (other than the two in the post i mentioned be4-which im looking for a diagram for so i can fix that issue)...i didnt check the ignitor but ill do that this evening or tomorrow evening...i also FINALLY got a filter for my maf and bolted it and the maf down SOOOO thats were i am...ill keep everyone posted
8ggalant
Car: nissan cefiro
Ok. so she started for me today...all i did was clean the plugs and set the timing to stock (cant remember the number off the top of my head- it was fully retarded though)...i still have a few thing i didnt check that i need too and i still have a few issues...ive been reading the fsm and learning alot so if anyone "new" to the forums is reading this, when sumone tells u to read the FSM...DO IT lol...anyway i have a few more issues that i plan to consult the Manual w/ but im gonna ask u all for you opinions anway..here goes:
Ok the original reason for this thread was that the car would not rev throught the rpm range smoothly..it was "jumpy" a few people told me it may be because i was running an open maf ..so i got a replacement maf (just in case) and a filter...but its still happening...any other suggestions??
Also, the car wilol only idle for a few minutes then the rpm will slow start bouncing up and down and the engine will die...I was reading a few post (including bios' new one) and it said people are running fpr's w/ there fuel pump..well i bought the car w/ a stock fpr and 255lhr walboro and it ran fine until now...u think that may be the problem...opinions appreciated...
Well thats about it...any help/advice is appreciated and i shall keep u updated....THANKS to all the people who have been helping me this far (i honestly was about to give up and pay sumone but u guys keep me thinkin positive)
8ggalant
Car: nissan cefiro
woooohooooo...got it runnin today..one of my buddies came and got the car runnin for me...he did everything i did again and came to the same conclusion....NUTHING..lol no codes on the ecu..hmmmm...lets swap out the cas....oh snap...runnin like a clock...perfect...so...now i need to buy a cas...
good thing..he left his chipped ecu in the car...ill be buyin that lol...just wanted to give yall an update..
so...anyone have a cas sittin around i can buy...ill trade ya or cash...i havea spare resistor pack and a maf ..i also have a flywheel i bought from a memeber on here when i was gonna buy kaz's motorset but i bought an already swapped car...now its just takin up space...let me know...thanks
kevin
sdtouge
Car: 1990 240sx coupe
nice. congradulations!
ca18detizzle
nice... yeah ive been reading the FSM. I printed it all out. Three 2inch notebooks. I work at kinkos. heh. good work!
8ggalant
Car: nissan cefiro
damn u lol...i need to print this thing out...im a crappy NOTE TAKER so theres nothing like writng down the steps to do sumthing and get out to the car and it doesnt make sense lmao..
f s t caz
congrats. glad to hear you finally got it running. you're gonna have to let me know when you get it driving again.
boost_boy
8ggalant wrote:woooohooooo...got it runnin today..one of my buddies came and got the car runnin for me...he did everything i did again and came to the same conclusion....NUTHING..lol no codes on the ecu..hmmmm...lets swap out the cas....oh snap...runnin like a clock...perfect...so...now i need to buy a cas...
kevin
Hey kevin,
I'll do an exchange with you if you still need a CAS.
Dee
Dee
8ggalant
Car: nissan cefiro
dee ill email u
ok replaced the cas w/ one off of a DE fromteh local U-pull-it...went to set/check the timing..and realized my father in law had the oldskool/non digital timing gun/light...i have no idea how to read taht thing...but yea i put the cas in @ "the middle" setting and it idles perfect (bad cas was almost fully retarded for the car to idle right)....so yea i still need to check timing....
BUT...i cant win for losing lol...every once in a while the car sptters sounding like a wrx and power is noticably lower..its still boosts fine...just sluggish...it happens then goes away while driving...i saw a post on here about it so im gonna check that...and make sure my timing is correct...any sugeestions about the boxer sound/lack of power?? {PS it was doint this w/ the bad cas too...and i havent checked if the cas i bought was a good unit either as i didnt have my FSM w/ my @ my inlaws house-...just ASSUMING its good as the car idles fine now tho i still need to check the timing}
as always ill keep everyone updated
8ggalant
Car: nissan cefiro
drove it to work today...just tryin not to put my foot in it too much as im not finish messing w/ the timing...hit me up
[email protected]
kevin
8ggalant
Car: nissan cefiro
boost_boy wrote: Hey kevin,
Dee
Dee
dee i emailed you , dunno if u got it or not. Im interested in doing the exchange. Do you need cash also? Let me know.
Kevin
float_6969
That sound is usually from some sort of timing problem. I still suspect a bad/weak ignitor or maybe a coil pack. Check the grounds again too.
8ggalant
Car: nissan cefiro
yea ill keep tryin float...im gettin a spare ignitor and coilpacks are on the way...we'll see
