New install having boost/driving issues
RM12577
Car: 89 Nissan 240SX with CA18DET
94 Nissan vert in need of work
Alright we start at the top, I installed my engine around a month ago. It started and ran, go figure. I didnt have a boost gauge on it at first and it ran pretty bad but it did run. no leaks and no real bad issues with it other than it running poorly. looked around to see what it might be and decided it had to be a boost leak. tightened all of my clamp and it made it run slightly better. I am now stuck with it running alright down low and when it is in high rpm's but if i run it wot it pops and bangs and it just wont go anywhere. sometimes the boost spikes really high and it will try to spool a lot spikes high as in like 12-15psi. i dont know if maybe i should try to disconnect something or eliminate something from the engine. working on a good boost leak tester at the moment cuz the tire valves i got dont work with my air compressor for some reason so im looking for better ones than the ones they sell at wal-mart. any ideas as to what to check would be nice.
Carl
capowered240
Car: 90 240sx
What kind of mafs do you have on it?
Modified by capowered240 at 11:33 PM 9/13/2007
RM12577
it has the CA18DET mafs on it still and its connected and wired properly. I cant figure out what it is Im going to go to an import shop that i was told deals with boosted engines a lot and see what they think is up with it maybe get some ideas from them. anything anybody could think of for me to check and whatnot would be helpful.
boost_boy
Please read this thread and read it well! And once you have followed some of the advice given you can start a new thread with the available informatin that will help us, help you. I'm not being a prick, but this forum is getting to be a big complaint stop and toomany people are not happy with their projects because some are too lazy to read or are just too ignorant to care about the advice given that can help them.
zerothread/230677
Dee
