Thats a mean piston speed of what, 48 meters per second? These heads are great but they aren't magicalReno wrote:omg imagine a fcw crank ka with this 15,000 rpm wohoo
Yep, same idea as with valves, it's just instead of a valve opening up it's like a little chamber has been opened up. This is really interesting. Extremely innovative, that's for sure. If it created a good seal, it would make for a much more rev happy engine. No more floating valves. That is thinking right there. Good stuff.oz240red wrote:That's so f$%n creative. I can see how the exhaust gasses are pushed out. But how is the mixture pulled in? Is it because the piston creates a vaccum effect on the small chamber??....
nissan_star wrote:now wait a sec, besides my curiousity about the seal, what about turbo?
would having a set intake charge volume automatically limit power production? instead of filling an intake manifold then going directly to the piston, it goes to a chamber of size x and size x fills the piston.
nissan_star wrote:would having a set intake charge volume automatically limit power production? instead of filling an intake manifold then going directly to the piston, it goes to a chamber of size x and size x fills the piston.
Perhaps CSRV technology would require a new approach to turbocharging which takes into account the total volume of the intake valvetrain instead of the short block's displacement. Turbocharging is nothing more than a way to make a given engine more efficient; to improve power output for a given engine size. Maybe engine efficiency is so much improved with CSRV that turbocharging would not make the drastic difference it makes now. Our power goals could then be attained with milder turbo builds.eazye2000 wrote:The cylinder is a 1lb coffee can. The 'spherical valve area' is a bathroom dixie cup.How is pressurizing that 'dixie' cup at first, and then having it decompress into the 'coffee can' going to be a good way to turbo?Whereas, before, we were straight up pressurizing, and filling the coffee can directly with fuel and air..?
what im saying is that when the intake rotor is opened into the pressurized intake manifold, will the pressurized air push the valve like wind on a sail and there fore take load of the valvetrain therefore making it more effiecent.Chris28 wrote:All a turbo does is cram air into the cylinder, it doesn't have anything to do with the size of the cylinder. Think of these rotary valves as camshafts. They are spun via a belt or chain, not by pressure.
I dont think this is true. Looking at your roots supercharger above, seems similar but it is fed off of the rotating assembly by gears that make it spin much faster then the actual valvetrain. Take that into acount, however, and imagine the rotor valves spining twice around during the intake charge, therefore it could be adding slight boost like your supercharger...martins_240sx wrote:I dont think you would really need boost. Think about it, essentially this thing almost acts a supercharger, well atleast one that is on some of the vehicles Ive seen in the military. If you had a larger sphere, one that gulps more air, then it would also push more air into the cumbustion chamber making more power, ie forced induction.
Carburetors???S13FX wrote:Any one find how fuel is injected into this?
I take it you forgot about the pistons? I can only imagine the size of the rods you would need to rev that high.martins_240sx wrote:why couldnt it survive that. there is no recipricating mass
