Ron Burgundy »
https://forums.nicoclub.com/ron-burgundy-u136089.html
Thu Feb 17, 2011 12:30 am
Jeez, take it easy buddy.
Q: What is the largest tire I can run with factory suspension?
A: It is not recommended to use a tire taller than 31" as it can cause rubbing on the fender flares or front bumper. You may be able to fit larger tires, however that would require removal of the fender flares as well as an aftermarket bumper (unless you cut away some of the front bumper) and other various trimming/bending.
Q: What is the largest tire I can run with the A.C. (Automotive Customizers) lift?
A: With some serious trimming and bending you may be able to fit as large as a 34" tire, given the fender flares are removed and an aftermarket front bumper is used (unless you cut away some of the front bumper). The A.C. lift has different outcomes on different vehicles, some net more than 2" of lift (after settling) which can allow for larger tires.
