I did it first...dangeris wrote:Joe's behind the time...Phenom has did it and done it as well as me
Yes, you simply plug the power wire into the fuse for the headlights... I'm not sure if that fuse is in the interior fuse box, or in the fuse box located in the engine bayanthonyle2002 wrote:is there any way to have the lights on all the time without using a switch? i basically want them on whenever the automatic headlights turn on.
that's something i wouldn't be looking forward to, cutting and drilling beside a huge mess of wires isn't something i'd be really comfortable withtoxik wrote:
if you know where to drill, its not that bad... some folks just aren't that comnfortable with power drills and wires though...coupecrazy1232 wrote:i did mine myself!!! yeah it took a couple minutes but it wasnt anything major!
I just checked, the headlight fuses are indeed inside the engine bay, you will need to go through the firewall...toxik wrote:
HAHAHAHAHA y dont u ask the guy who did my foglights $800 worth of damage from f***ing it upcoupecrazy1232 wrote:
yea but i did the ac vents first "all of them meaning"rjdmmfl1 wrote:
I did it first...
true but if u arent u shouldnt be modding ur car if u cant handle a power drill lolrjdmmfl1 wrote:
if you know where to drill, its not that bad... some folks just aren't that comnfortable with power drills and wires though... s
sounds good!!!Racingline wrote:hey guys just answer a few quick question on these.
-Racingline does not make these kit's, they are built by a another company with insight and product from VLEDS.
-they are full plug and play and wire into a select circuit in the BCM module so that they operate when ever you unlock the car or turn on the dome light.
- Detailed installation instructions are provided, and no these do not plug into the lighter or need to go through the fire wall.
-the switch kit allows for full time ON operation and comes with a larger than standard 3 way non illuminated switch that will fit the OEM switch panel to the left of the steering wheel. It is not a $2 radio shack switch.
-Lines are capped and ready for you to add the switch of your choice should you not like the switch option associated with the kit.
I think that's about it for now. feel free to PM me if you have any other questions. I'm working on getting some pics of the other colors installed up on the website as well.
Modified by Racingline at 8:32 PM 2/4/2010
