Fireplug wrote:Couple of questions on your setup if you don't mind...
1.) I ordered my splitfire...I was told the replacement coilpacks they provide don't allow for the stock coilpack cover to fit....it appears as though your coilpack cover is on...is that picture with the Splitfire coils on also?
2.) I am also running a Turbonetics 62-1 turbo and aiming for the 500whp range...what are the specs on your 62-1? Did you go with the .63 ar and stage 5 wheel?
3.) I'm having some serious issues with slicks and offsets....I saw you have some MT slicks on your stock alloys...what size are the slicks? Any kind of fender rolling or spacers? I'm hoping to cram a 26x10.5-16 in the rear...
4.) When aiming for the 600whp range...I've found people have a few problems with their SR's...their stock coils run out of spark (which you've obviously addressed) and fuel becomes an issue. Are you upgrading your injectors? I got rid of my denso 720 for a set of MSD 96 lb/hrs and will be running a 2nd Walbro 255lph fuel pump with -8 feed and -6 return line...what's your fuel plans?
Awesome #'s for having stock cams and bottom end!!! That's very promising! I'm relieved that someone has a similar setup to mine and is putting down those kind of #'s...I was starting to worry that my 62-1 wasn't good for it!
Modified by Fireplug at 11:22 AM 5/2/2005
1) It will fit. It is a little tight but it will bolt in.
2)You will be fine aiming for the 500whp range with the 62-1 with the t3 stage 5 exhaust housing but I have upgraded to the t4 .58 p trim housing and also have a .68 exhaust housing and wheel to try with the HKS 272's
3)Mine are 26x10.50 et streets with no spacers on the wheels. I wouldn't suggest 16" wheels because if the car hooks and the suspension is allowed to squat with adjustable shocks, the fender will hit the tire if it is any farther out. One a side note: I have adapted a 300z trans into the car to hold up to the twinplate exedy clutch which allows for better 60ft times. The best so far with a low setting on the 2 step was a 1.57.
4)I will probably end up running a frame mount pump and dual -8an lines and rc1200cc injectors to replace the 750cc's I have now for the fuel problems. As for the coil packs, I have already taken care of that with the Splitfire.
